self adhesive conduit-does it work?
Old 13-05-2009, 3:57 PM   #1
21,436, Level: 35
Points: 21,436, Level: 35 Points: 21,436, Level: 35 Points: 21,436, Level: 35
Activity: 5.8%
Activity: 5.8% Activity: 5.8% Activity: 5.8%
Thanks: Gave 239, Got 101
Just wondering if anybody has used plastic conduit/channels of the self adhesive variety and had any problems?
My experience of other self adhesive products is that after a while the glue 'dies' and then things come apart.
Old 13-05-2009, 4:12 PM   #2
2,425, Level: 11
Points: 2,425, Level: 11 Points: 2,425, Level: 11 Points: 2,425, Level: 11
Re: self adhesive conduit-does it work?
I've used it in my study to route the cables for 7.1 speakers around the top of the ceiling, and in the corner of the wall, without any issues. Still shows no sign of coming away.
Old 13-05-2009, 4:26 PM   #3
243418's Avatar
2,648, Level: 11
Points: 2,648, Level: 11 Points: 2,648, Level: 11 Points: 2,648, Level: 11
Thanks: Gave 22, Got 12
Hi Indus,
It works! But be sure that you stick it in the right place first time round. The adhesive is strong enough to pull off plaster if you need to move it.
Cheers, Mike
Old 13-05-2009, 5:52 PM   #4
9,165, Level: 22
Points: 9,165, Level: 22 Points: 9,165, Level: 22 Points: 9,165, Level: 22
Activity: 3.0%
Activity: 3.0% Activity: 3.0% Activity: 3.0%
Thanks: Gave 217, Got 360
I tend to avoid the stuff, unless combining it with strategically placed screws wherever it's likely to be a problem - I've seen it come away so many times.
Old 13-05-2009, 5:53 PM   #5
21,436, Level: 35
Activity: 5.8%
Many thanks
243418, I notice we have the same pj
Old 14-05-2009, 12:53 PM   #6
3,988, Level: 14
Points: 3,988, Level: 14 Points: 3,988, Level: 14 Points: 3,988, Level: 14
Thanks: Gave 5, Got 8
I bought some from B&Q and started to come off within a day or so
Old 14-05-2009, 1:09 PM   #7
21,436, Level: 35
Activity: 5.8%
Aha! Thats what I was scared of. Maybe there are better makes?
Old 14-05-2009, 1:56 PM   #8
1,519, Level: 8
Points: 1,519, Level: 8 Points: 1,519, Level: 8 Points: 1,519, Level: 8
Activity: 2.0%
Activity: 2.0% Activity: 2.0% Activity: 2.0%
Thanks: Gave 457, Got 190
strange, ive done my 5.1 with b and q conduit, and its stuck fine for the last 5 years, all i did was make sure the surface was completely flat and clean before sticking on, if yor worried you can buy it without the sticky stuff on and then use some no more nails adhesive, then it wont go anywhere guarenteed
