Where to get trunking for speaker cable
Old 09-05-2009, 2:44 PM   #1
sisko's Avatar
5,895, Level: 18
Points: 5,895, Level: 18 Points: 5,895, Level: 18 Points: 5,895, Level: 18
Thanks: Gave 14, Got 17
Can any one tell me where to get conduit/trunking for my surround speakers.
I can get 16mmx10mm at Screwfix Self-Adhesive Trunking 10 x 16mm - Screwfix.com, Where the Trade Buys, but is there anywhere to get smaller trunking, say 10mmx100mm?
I want to keep the cabling as neat as possible. The 16x10 will do if I can't get anything smaller.
Thanks in advance.
Old 09-05-2009, 3:00 PM   #2
wingnut121's Avatar
3,434, Level: 13
Points: 3,434, Level: 13 Points: 3,434, Level: 13 Points: 3,434, Level: 13
Thanks: Gave 114, Got 104
Re: Where to get trunking for speaker cable
bnQ has a few different styles, check out there site, i got some white D trunking from there
Old 09-05-2009, 3:06 PM   #3
MacReady's Avatar
14,071, Level: 28
Points: 14,071, Level: 28 Points: 14,071, Level: 28 Points: 14,071, Level: 28
Thanks: Gave 218, Got 61
Ikea sell trunking in their lighting section that is quite cheap. I have used a bit of it in my set up.
Old 09-05-2009, 3:43 PM   #4
6,337, Level: 18
Points: 6,337, Level: 18 Points: 6,337, Level: 18 Points: 6,337, Level: 18
Thanks: Gave 36, Got 29
checkout here: D-Line Mini Trunking 16mm x 8mm White Self Adhesive
They also do all the bits to join and bend
Old 09-05-2009, 4:12 PM   #5
sisko's Avatar
5,895, Level: 18
Thanks Such.
Had a look at TLC and they had 11mmx8mm but were looking over £40 delivery for a £13 order.
Googled the trunking they had and got this instead:
Trading Depot - Self Adhesive Mini Trunking 11mm x 8mm x 3m
Only £20 delivered for 15 meters.
