The Current Room
Due to it's relatively small dimensions the room suffers quite badly from reflections. When playing at higher levels things can become overpowering as standing waves build up. I've therefore come up with this design for further room treatments to hopefully create a more pleasant listening environment.
Having a larger distance between the panel and the corner should create a decent amount of bass absorption compared to standard wall panels.
The whole thing is designed to be as light as possible considering it needs to be mounted to the ceiling. There's no way I want to risk them coming down.
Once completed they will be wrapped in acoustic fabric and held up by heavy duty velcro along the black shaded areas. Finding some white fabric at a reasonable price is proving difficult though, the cheapest I've found is more than triple what the black cloth from Maplin costs. The rocksilk will also have some straps across it at the back to stop it moving once in place.
At the moment I'm still gathering materials and considering the design. Splitting them into 2-3 smaller panels may be easier to handle...
Has anyone else done anything similar to this with success? I've seen a few ceiling corner mounted panels on american sites, but could never figure out how they held them up. So this is what I came up with as a solution.
The Planned Result
More to come soon...
