Extension and new DIY multi-room install
Old 08-05-2009, 2:24 PM   #1
7,185, Level: 20
Points: 7,185, Level: 20 Points: 7,185, Level: 20 Points: 7,185, Level: 20
Thanks: Gave 280, Got 96
I have a home cinema and media cabinet and now plan distrubute this to other parts of the house in particular the new living room and kitchen.
But I thought it may be useful to people to show how useful it is using sketchup when planning layout etc when we did our extension. Really found it useful when planning kitchen layout.
Our home before
Plans
I used sketchup to plan our side extension on the right hand side of the house. (Extension above the garage to follow at a later date).
This sketchup plans helped with the architect plans and vice-versa.
Overview of the extension and exisiting part of the house using sketchup
Exterior front extension
Exterior rear extension
Kitchen (front extension)
Living room (rear extension)
Execution
more to follow... building works, cables and some of the av stuff !
Old 08-05-2009, 2:25 PM   #2
7,185, Level: 20
Re: Extension and new DIY multi-room install
reserved
Old 08-05-2009, 2:53 PM   #3
3,282, Level: 13
Points: 3,282, Level: 13 Points: 3,282, Level: 13 Points: 3,282, Level: 13
Thanks: Gave 11, Got 6
So is that the free version of sketchup or the pro?
Old 08-05-2009, 3:14 PM   #4
7,185, Level: 20
Free version.
The renders that look really nice (with light effects etc) use a rendering engine though called Kerkythea which can be exported to from sketchup. This just adds the polish to the hard work done in Sketchup. Rendering can be slow.
Other free rendering engines available too like podium etc. Bit of a learning curve but good fun IMO.
Old 08-05-2009, 3:24 PM   #5
2,595, Level: 11
Points: 2,595, Level: 11 Points: 2,595, Level: 11 Points: 2,595, Level: 11
Thanks: Gave 1, Got 10
hey buddy what's the flooring you used for the kitchen? the shinny one.. looks good..is that ceramic tile?
Old 08-05-2009, 3:53 PM   #6
7,185, Level: 20
Porcelain.. style is french limestone, size is 80 by 40cm.
I'll get some better shots of it as you cannot really see it with the light.
Old 08-05-2009, 9:14 PM   #7
1,975, Level: 10
Points: 1,975, Level: 10 Points: 1,975, Level: 10 Points: 1,975, Level: 10
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 37, Got 22
Thats quality fella, looking forward to more pics.
Old 07-08-2009, 10:45 AM   #8
3,071, Level: 13
Points: 3,071, Level: 13 Points: 3,071, Level: 13 Points: 3,071, Level: 13
Thanks: Gave 10, Got 2
Your kitchen looks amazing! Nice work - also nice work on the renders!
Old 07-08-2009, 12:01 PM   #9
4,776, Level: 16
Points: 4,776, Level: 16 Points: 4,776, Level: 16 Points: 4,776, Level: 16
Thanks: Gave 29, Got 24
Very impressive! Kitchen looks amazing
I looks forward to reading about what you've put into the place re. multi room too. We have our new kitchen going in under the cinema/media room so will be putting in some Av kit in the there also.
