| Black Furniture Paint
Hello All,
I`m building a large cabinet unit for disc storage to be painted black, the last unit got a reflection from the projection screen and was visible in your eyeline to the side and became quite annoying, so this unit needs to have a very matt finish with no reflections.
I`ve tried proper mdf / furniture paint and although it sets hard and gives a proper coating that doesn`t mark I`ve only seen this available in satin finish which does give a reflection. The best type of black I`ve used is International One Coat Matt Black which gives the perfect dull black finish with no reflections at all but this marks far too easily, even with your hands and just spoils the finish.
I`ve thought about sealing this coat with a clear matt varnish but that ends up looking like satin and gives reflections.
Has anyone used any types of black paint I could try ?
Proper mdf paint would be the best option for durability as long as it`s matt finish not satin, ideally I want to use a spray gun for the paint.
Hopefully someone can point me in the right direction.
Thanks very much in advance.
Dave
