Best Paint Projector
Old 03-05-2009, 12:57 PM   #1
3,143, Level: 13
Points: 3,143, Level: 13 Points: 3,143, Level: 13 Points: 3,143, Level: 13
Thanks: Gave 13, Got 0
hi guys i have a my optoma hd65 on a 90" greywolf 2 pull up screen am moving to a bigger house and want to paint the wall its about 150" wots the best paint to paint the wall with any help would be great..........
Old 04-05-2009, 8:06 AM   #2
Illustrious Member
Azzin's Avatar
54,465, Level: 57
Points: 54,465, Level: 57 Points: 54,465, Level: 57 Points: 54,465, Level: 57
Activity: 61.0%
Activity: 61.0% Activity: 61.0% Activity: 61.0%
Thanks: Gave 4,004, Got 1,320
Re: Best Paint Projector
I useed Vogel's Invisible Wall Paint, very happy.
PS-"Wots"....?
Sammy2008 (05-05-2009)
Old 04-05-2009, 8:58 AM   #3
Mep Mep is offline
Conspicuous Member
Mep's Avatar
14,376, Level: 28
Points: 14,376, Level: 28 Points: 14,376, Level: 28 Points: 14,376, Level: 28
Thanks: Gave 442, Got 465
Hi Azzin, where did you get the Vogel paint from?........have googled but can't find anyone that sells it
Old 04-05-2009, 9:39 AM   #4
Illustrious Member
Azzin's Avatar
54,465, Level: 57
Activity: 61.0%
Looks like it's discontinued: Vogels MPW10 - Mighty Brighty - Projection Screen Wall Paint, covers up to 5m2 - MPW10
[Edit] - http://www.cyberselect.co.uk/range/1637
Mep (04-05-2009)
Old 04-05-2009, 9:56 AM   #5
Mep Mep is offline
Conspicuous Member
Mep's Avatar
14,376, Level: 28
Thanks mate.
Old 05-05-2009, 8:05 AM   #6
3,143, Level: 13
thank you Azzin m8
Old 05-05-2009, 8:31 AM   #7
3,143, Level: 13
Azzin m8 just watch a video on that paint m8 theres alot of paint mixing i thought it was just 2 pots of paint and off you go is it easy to mix or how do the picture look on yours m8 any pics ty
Old 05-05-2009, 3:28 PM   #8
6,621, Level: 19
Points: 6,621, Level: 19 Points: 6,621, Level: 19 Points: 6,621, Level: 19
Thanks: Gave 250, Got 21
BWUK DIY Paint
I've used the Black Widow UK (BWUK) mix.
Link1, Link2 and Link3 to some pics (not mine) for your review from the long thread !
Plenty more in there if you want to browse the thread.
Hopefully of some interest.
