Node o Build - How many plugs can I have on one adaptor?
Old 01-05-2009, 5:56 PM   #1
newstuart's Avatar
8,165, Level: 21
Points: 8,165, Level: 21 Points: 8,165, Level: 21 Points: 8,165, Level: 21
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 44, Got 35
Hi All
I am building a Node 0 into a recess in my office with venting up into the attic. I have fitted racking and have 12 items needing power, at present I have one double socket next to the recess and am wondering how to safely power everything.
Here is what I need to power,
1) HTPC - on 24/7
2) Sky Box - Feeds pc - on 24/7
3) PS3 - on occasionally
4) Xbox - on for a few hours a day as a MCE extender
5) Amp - on when watching HTPC
6) 12v Power Supply for IR distribution - on 24/7
7) Home Router - on 24/7
8) Home Switch - On 24/7
9) Work Router - on 24/7
10) Printer/Fax combo - on 24/7
11) Dock for work Laptop - on 8 hours daily 3 in 7 days
12) VOIP box - on 24/7
Can this be powered with extension leads or am I asking for my house to be burnt down doing this?
Old 01-05-2009, 6:07 PM   #2
13,312, Level: 27
Points: 13,312, Level: 27 Points: 13,312, Level: 27 Points: 13,312, Level: 27
Activity: 54.2%
Activity: 54.2% Activity: 54.2% Activity: 54.2%
Thanks: Gave 1, Got 523
Re: Node o Build - How many plugs can I have on one adaptor?
Just add up the power consumptions... Some really bad estimates below
200W HTPC - on 24/7
35W Sky Box - Feeds pc - on 24/7
100W PS3 - on occasionally
100W Xbox - on for a few hours a day as a MCE extender
500W Amp - on when watching HTPC
5W 12v Power Supply for IR distribution - on 24/7
5W Home Router - on 24/7
5W Home Switch - On 24/7
5W Work Router - on 24/7
20W Printer/Fax combo - on 24/7
65W Dock for work Laptop - on 8 hours daily 3 in 7 days
5W VOIP box - on 24/7
= 1045W
A single 13A socket is good for 3120W
Old 01-05-2009, 6:36 PM   #3
newstuart's Avatar
8,165, Level: 21
Activity: 0.8%
Thanks for that.
So looking ok, now need to find an extension lead with enough sockets as I do not really want to daisy chain a load together
Old 01-05-2009, 6:43 PM   #4
2,434, Level: 11
Points: 2,434, Level: 11 Points: 2,434, Level: 11 Points: 2,434, Level: 11
Thanks: Gave 10, Got 13
How about this?
http://www.argos.co.uk/static/Product/partNumber/0461618/Trail/searchtext>MASTERPLUG.htm
Has 8 sockets, you could then get a standard 4socket adapter for the low-risk items such as modem/router/switch.
Tis exactly what I do .
Old 01-05-2009, 7:04 PM   #5
13,312, Level: 27
Activity: 54.2%
I was just giving an example by the way. You should redo the calcs with your kit just to be on the safe side.
For example, I have no idea what amplifier you have, nor what the max consumption of your HTPC is.
For the smaller devices that don't show the power consumption, a safe calculation is this:-
Volts * Amps * 2
So a 12V, 2.5A power supply would be 60W (the reason for doubling it is that most power supplies are very inefficient.
Steve
