Home made AV rack
Old 26-04-2009, 12:20 AM   #1
3,560, Level: 14
Points: 3,560, Level: 14 Points: 3,560, Level: 14 Points: 3,560, Level: 14
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 18, Got 16
Home made AV rack
I decided that I didn't want to spend a fortune on an AV rack and I couldn't get one deep enough to fit the PC so I decided to make my own.
I got some 18mm mdf cut to 600 x 600mm from B&Q then cheated and got the local carpentry place to drill the holes in the right place for me, cut out a recess at the back of the shelves and router the edges - All for £35!
They did 8 shelves for me (although I only ended up using 6). I also picked up some casters from Ikea as well to make it easy to move about:
What it is replacing (Ikea shelving unit):
Plenty of space for cable management and air flow
Bit of a pain to put together and at some point i'll have to take it all apart again (not until I have fitted the new skirting boards and the new carpet has been delivered though!)
It's still not all plugged in (got to plug in the tape drive and Wii):
PC is plugged into the Tosh LCD and this small touch screen:
Cost wise:
MDF - ~£15.00
Metal Rod - ~£15.00
Bolts and Washers - ~£15.00
Wood cut to size - £35.00
Castors (Ikea) - £14.00
Old 26-04-2009, 10:17 AM   #2
KUBBY's Avatar
11,147, Level: 25
Points: 11,147, Level: 25 Points: 11,147, Level: 25 Points: 11,147, Level: 25
Activity: 16.3%
Activity: 16.3% Activity: 16.3% Activity: 16.3%
Thanks: Gave 127, Got 570
Re: Home made AV rack
Very nice indeed and a credit to you.
Just a thought,perhaps some Dome Nuts or Covers over the top nuts just to finish it off ?
KH
Old 26-04-2009, 11:57 AM   #3
3,560, Level: 14
Activity: 1.0%
KH
I've got to take it apart again at some point to paint the shelves (unfortunately as it takes a long time to get all the nuts in the right places) and I was thinking about getting hold of some dome nuts to go on the top.
I feel much happier about the kit staying cool as well now
Old 27-04-2009, 2:21 PM   #4
4,305, Level: 15
Points: 4,305, Level: 15 Points: 4,305, Level: 15 Points: 4,305, Level: 15
Thanks: Gave 17, Got 6
Looks good, might do something very similar myself. Is there one long metal threaded rod going through every shelf in each corner, and then the waher/bolt above and below holds each shelf in place? If so where did you get the long rods from from?
Old 27-04-2009, 2:30 PM   #5
1,493, Level: 8
Points: 1,493, Level: 8 Points: 1,493, Level: 8 Points: 1,493, Level: 8
Thanks: Gave 1, Got 26
haha, quality use of a bit of threaded bar! i love it!
Old 27-04-2009, 2:36 PM   #6
3,560, Level: 14
Activity: 1.0%
Exactly that...
I got the rods online, when I get home i'll dig out the link for you.
There's a bit of flex in it but then it is called a "TNT FlexyRack"
Old 28-04-2009, 3:16 PM   #7
yeswotever's Avatar
1,830, Level: 9
Points: 1,830, Level: 9 Points: 1,830, Level: 9 Points: 1,830, Level: 9
Thanks: Gave 1, Got 3
How is the little touchscreen part of your system?
Old 28-04-2009, 3:28 PM   #8
3,560, Level: 14
Activity: 1.0%
It's plugged into the Media Centre PC via a dual output graphics card.
Longer term the plan will be to run some cabling out to the kitchen so that I can move the screen out there (already have speakers in the kitchen ceiling)
Old 14-05-2009, 3:17 PM   #9
yeswotever's Avatar
1,830, Level: 9
I'd like to see how that comes out is it done yet?
