New fake chimney to take Plasma-Lcd! Day 4
Old 19-04-2009, 7:54 PM   #1
2,709, Level: 12
Points: 2,709, Level: 12 Points: 2,709, Level: 12 Points: 2,709, Level: 12
Thanks: Gave 0, Got 6
Day 4 and the lights go on Hope you like this installation Please leave me some feed back !
I will leave some more pics when the final touches are added !
Many thanks
Old 19-04-2009, 7:57 PM   #2
3,076, Level: 13
Points: 3,076, Level: 13 Points: 3,076, Level: 13 Points: 3,076, Level: 13
Thanks: Gave 25, Got 29
Re: New fake chimney to take Plasma-Lcd! Day 4
i really like the lighting through the gaps, nicely done!
Old 19-04-2009, 10:11 PM   #3
solidamber's Avatar
3,782, Level: 14
Points: 3,782, Level: 14 Points: 3,782, Level: 14 Points: 3,782, Level: 14
Thanks: Gave 44, Got 116
I see your next door neighbour has their lounge light on,
Old 20-04-2009, 5:04 PM   #4
4,366, Level: 15
Points: 4,366, Level: 15 Points: 4,366, Level: 15 Points: 4,366, Level: 15
Thanks: Gave 24, Got 54
love the back lighting effect. That is some careful scribing around the cornice to get a nice equal gap and all the way around. Is each side done in 1 sheet?
Old 20-04-2009, 5:44 PM   #5
2,709, Level: 12
Yes the side panels are just under a full sheet of MDF each and they are mounted on 2x1 timber !
The rope lights also run through the cabinets to provide lighting of the equipment ! More pics of this to follow.
Old 20-04-2009, 5:52 PM   #6
2,709, Level: 12
More pics of this installl !
http://s166.photobucket.com/albums/u...sallation%201/
Old 21-04-2009, 8:03 AM   #7
Kenny Glasgow's Avatar
12,077, Level: 26
Points: 12,077, Level: 26 Points: 12,077, Level: 26 Points: 12,077, Level: 26
Thanks: Gave 71, Got 228
Nice work Scotty, look forward to seeing more pics
Old 21-04-2009, 8:26 AM   #8
6,709, Level: 19
Points: 6,709, Level: 19 Points: 6,709, Level: 19 Points: 6,709, Level: 19
Thanks: Gave 35, Got 42
Absolutely stunning mate!
Old 21-04-2009, 12:18 PM   #9
3,718, Level: 14
Points: 3,718, Level: 14 Points: 3,718, Level: 14 Points: 3,718, Level: 14
Thanks: Gave 21, Got 55
You have a tron living room!
Old 21-04-2009, 3:21 PM   #10
6,583, Level: 19
Points: 6,583, Level: 19 Points: 6,583, Level: 19 Points: 6,583, Level: 19
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 516, Got 76
Really, really nice. I have a few questions, if you don't mind. When putting in the drop down doors, how do you where to mark inside for the hinges? And what thickness is that MDF and was it easy to work with, as i'll be starting mine soon, so any tips please share.
Old 21-04-2009, 3:56 PM   #11
yeswotever's Avatar
1,830, Level: 9
Points: 1,830, Level: 9 Points: 1,830, Level: 9 Points: 1,830, Level: 9
Thanks: Gave 1, Got 3
That looks fantastic, how did you mount the TV?
Old 21-04-2009, 4:41 PM   #12
12,077, Level: 26
oooh err
Old 21-04-2009, 4:45 PM   #13
2,709, Level: 12
Hello mate glade you like the latest installation.
The TV was mounted on a bracket that has a scissur action arm on the back; this allows you to adjust the TV in most directions and allows it to be pulled out for easy cable insulations!
The bracket I used was bought from eBay for around £60 delivered! CLICK THE LINK TO SEE A PIC !
Google Image Result for http://img.chinapages.com/photo/51047000/Plasma_Bracket.jpg
Hope this helps!
Old 21-04-2009, 5:28 PM   #14
2,709, Level: 12
Hi nice to see you like this installation for a new client!
The hinges are easy to fit if you take your time to practise on a spare peace of MDF, Place two pieces of MDF together at a right angle.
Allowing for a 2mm gap in the joints.
Place the hinge in the corner of the sections and transfer the required information-measurements to the MDF with a pencil.
Square all your lines up with an adjustable square and then take notes on the positions of the holes that are required.
Drill the required hole in the door section to take the Blumb hinge; do not drill all the way through the MDF![IMG]file:///C:/Users/Scott/AppData/Local/Temp/msohtmlclip1/01/clip_image001.gif[/IMG]
When fitting the Blumb hinge be shore to fit it square too the door and frame- unit!
It’s best that you just have a play and keep looking at your kitchen doors and how they work, you might find some videos on YOU TUBE
Hope this helps
deefadog (21-04-2009)
Old 21-04-2009, 5:28 PM   #15
2,709, Level: 12
Originally Posted by Kenny Glasgow View Post
oooh err
So dont like what you see then ?
Old 21-04-2009, 6:25 PM   #16
Conspicuous Member
Paul_T's Avatar
21,874, Level: 35
Points: 21,874, Level: 35 Points: 21,874, Level: 35 Points: 21,874, Level: 35
Activity: 15.2%
Activity: 15.2% Activity: 15.2% Activity: 15.2%
Thanks: Gave 190, Got 733
beat me to it!
Old 30-04-2009, 12:12 AM   #17
3,787, Level: 14
Points: 3,787, Level: 14 Points: 3,787, Level: 14 Points: 3,787, Level: 14
Thanks: Gave 2, Got 0
thats mint
