My home cinema. A slow DIY build.
Old 19-04-2009, 3:47 PM   #1
1,864, Level: 10
Points: 1,864, Level: 10 Points: 1,864, Level: 10 Points: 1,864, Level: 10
Thanks: Gave 4, Got 3
My THX home cinema. A slow DIY build. Part 1
In my house is a cellar room of 6.80 metres length x 5 metres width x 2.85 metres height.
After leaving it more or less unused for many years (having discounted it as being too small for an indoor pool), I decided that we should have a games / party/ home cinema room / second lounge for our family with two teenage daughters. It took a little longer than I originally anticipated – but the technology got better and cheaper in that time, so I'm not complaining.
As is – it would seem – often the case, my wife saw no need for the cinema part of the idea. Thus a steady approach to realising this part of it was necessary But from early on I envisaged a large screen.
We agreed to wood panel the outer walls in a light-colour and my wife also insisted on a white ceiling.
We commenced with wood battening in autumn 2005. Unfortunately, I‘d only been doing this for a couple of days when I had an argument with a mountain in the dark which left me with a hand injury that prevented me carrying on for a while.
I replaced my wrecked car with one with a full roll cage
I informed my wife that I intended to do more virtual driving and make myself a 1:1 copy of my Lotus's cockpit.
But first the room's walls were battened and power cables run.
The ceiling was painted and new, high sound insulating double glazing was fitted.
I then used our projected home cinema room as a convenient workshop to build myself a cockpit – which caused some delay
Since completion it has given me hours of cheap amusement.
The gamers amongst you may recognise the Logitec G25 that has been somewhat modded with original Lotus Parts, so the controls are exactly as in the real car‘s cockpit.
Having completed that project, I finally returned my attention to the cinema project.
In addition to the existing stonewool insulation, I persuaded my wife that additional insulation was desirable. 60mm polystyrene was used between the 6x6 cm battens.
To improve the contrast in the very light room a black section around the screen was created.
Part 2 follows!
Old 19-04-2009, 3:52 PM   #2
1,864, Level: 10
Re: My home cinema. A slow DIY build.
Part 2
The screen wall was lined with plasterboard
The screen area (370 x 170 cm to give a 2.35:1 370 cm wide pic or 16:9 300 cm wide pic) was sprayed with matt grey car filler primer
The screen area was then sprayed with matt white car primer and masking panels were constructed using aluminium profile and hardboard.
Detail of lower guide rail for horizontal masking panel.
Detail of upper horizontal guide rail
Lower rail
One panel section in situ
Attention was also given to the PJ end of the room. Here 20mm insulation was applied as the room is adjacent to a wine cellar. The reason for the large wooden panel in the left of the pic will become apparent
A darts board conforming to the official regulations was envisaged. This would normally be concealed behind a panelled door (visbible in the left of the pic).
The vertical masking panel was fitted and laminate flooring laid.
Part three follows!
Old 19-04-2009, 3:57 PM   #3
1,864, Level: 10
Part 3
The screen wall surround was covered with carpet and black velvet and the masking panels also covered with black velvet.
The speakers were installed: Teufel System 5 THX Select 7.1. The other electrical equipment was ordered: Onkyo 876, JVC HD 750, Sony BDP-S550, Panasonic DMR-EX98V, Sony KDL-40Z4500 200Hz LCD (for casual use/gaming on N64, Wii, PS2 and PS3).
While awaiting the gear, attention was given to details.
The entrance door to the home cinema
Three tiers of seating
The rear podium is wheeled to allow reversal of the seating for viewing the 40“ Sony 200Hz behind it or to clear the centre of the room for parties.
Recesses in the base of the podium house the protective sections and regulation footbar for darts when not in use.
The „darts door“ (closed)
The darts door open
Safe darts for younger kids (normally concealed behind carpet panel)
Part 4 follows!
Old 19-04-2009, 4:01 PM   #4
1,864, Level: 10
Part 4
Rear wall with LCD and games consoles
The ceiling-mounted fluorescent tubes are for general purpose use. The wall-mounted halogen lamps are switchable and dimmable via remote control. The blue LED downlights in the back wall are also remotely controlled.
After three years of building, on and off, I was hoping that I had done my research adequately and that I would not be disappointed by the performance. With THX speakers, THX AV unit and THX PJ, I felt I should be OK –but the proof of the pudding is in the eating. I know that theoretically the speakers could be a class more powerful for this size of room – but my wife and daughters already resist my desires to "feel" the sound in our living room set-up where our 52" LCD and Onkyo 705 feed a humble set of Sony 5.0 speakers!
Last to arrive was my PJ – especially imported from Germany. Made the last connections late at night and was ready to give the set-up a trial run prior to a first film the next day!
Switched on the JVC HD 750 and was rewarded with a lens door that failed to open and an array of red lights!
Closer investigation revealed that there is a manual lens door button on the underside of the PJ. This is a metal construction which has a plastic cap. The plastic cap had somehow become detached and was wedged between the door and other parts, preventing the cover from opening. It could not be correctly positioned without opening the unit – which is expressly forbidden and would void the warranty. Dilemma! Returning it would mean several weeks futher delay. Judicious pushing on the jammed plastic part resulted in it disappearing from view! Question was would the cover now function, or had the part landed where it would still cause problems. Switched the unit on. Cover opened, lamp operated. I'm fairly sure that the plastic part will not cause any problems, so have accepted this.
Finally, get the family together and watch Wall-E blu-ray.
My impressions:
Even on my home-made car primer screen (no idea what the gain factor is), the contrast, vivacity and depth of the images is simply fantastic. On panning shots, the very slight irregularities in the finish of the screen are noticable to my critical eye – but apparently not to casual viewers.
The sound is in quite another class to my (already impressive to most who've experienced it) living room system. Sitting on the rear row sofa, on the podium, when the spaceship lands, the whole room seems to be shaking – this is cinema as I always wanted it! And, happily, no undesired resonances were detectable from my wood-panelling (which I had additionally sound-damped with window rubber sealing profile in critical places).
I‘ve not made any adjustments to the PJ. In THX mode it seems pretty good to me. I'm sure that the real gearheads will consider this almost criminal. I tend to follow a similar approach with other things too: I have the adjustable suspension on my Lotus set up for the Hockenheim F1 track, dry. Driving it with this setting on public roads is good enough for me. I haven't got the patience to delve that deeply into the theory, so, if I started adjusting things, I could easily end up worse than before!
Apart from the electrical (power) installation, I did all of the work myself – with the help of my wife and a friend when putting some of the heavier items in place (e.g. windows). My wife also did most of the tidying up which certainly helped my morale.
It took a long time, but we agree that it was worth it
Old 19-04-2009, 4:29 PM   #5
14,423, Level: 28
Points: 14,423, Level: 28 Points: 14,423, Level: 28 Points: 14,423, Level: 28
Activity: 3.8%
Activity: 3.8% Activity: 3.8% Activity: 3.8%
Thanks: Gave 1,340, Got 950
What a brilliant room. I like your Lotus parts modified gaming seat too. I'd so love to have a spare room to do this sort of thing myself. At least you've satisfied the 'gearheads' with your dark screen suround and curtaining near the screen, without making the room too dark and gloomy.
Old 19-04-2009, 4:51 PM   #6
7,094, Level: 20
Points: 7,094, Level: 20 Points: 7,094, Level: 20 Points: 7,094, Level: 20
Thanks: Gave 8, Got 5
very nice setup indeed and a concise thread
good luck with it all.
k
Old 19-04-2009, 7:37 PM   #7
Illustrious Member
Pecker's Avatar
43,925, Level: 51
Points: 43,925, Level: 51 Points: 43,925, Level: 51 Points: 43,925, Level: 51
Activity: 20.5%
Activity: 20.5% Activity: 20.5% Activity: 20.5%
Thanks: Gave 2,682, Got 1,886
What a smashing cellar conversion.
Kit list?
Steve W
Old 19-04-2009, 7:43 PM   #8
1,864, Level: 10
The kit list is in my posting – just above the Charlie Chaplin door pic
Pecker (20-04-2009)
Old 20-04-2009, 11:07 AM   #9
Stoatman's Avatar
11,970, Level: 26
Points: 11,970, Level: 26 Points: 11,970, Level: 26 Points: 11,970, Level: 26
Thanks: Gave 20, Got 89
Great room , that first picture looks scary
Old 20-04-2009, 11:11 AM   #10
1,864, Level: 10
Luckily the Lotus-built Opel Speedster (Vauxhall VX220 in the UK) has a tough roll bar!
Old 20-04-2009, 12:08 PM   #11
IanW's Avatar
8,953, Level: 22
Points: 8,953, Level: 22 Points: 8,953, Level: 22 Points: 8,953, Level: 22
Thanks: Gave 246, Got 92
Very nice room!
OMG the car crash looks pretty scary!
Old 20-04-2009, 10:42 PM   #12
2,792, Level: 12
Points: 2,792, Level: 12 Points: 2,792, Level: 12 Points: 2,792, Level: 12
Thanks: Gave 5, Got 5
Love the room.
Likin the Exige even more, is that Krypton green or Isotope?
These little cars are remarkably tough, seen a few owners walk away from big offs that woulkd have hurt in a normal car.
Old 21-04-2009, 12:01 AM   #13
1,864, Level: 10
Getting off-topic here!
It's Krypton Green
It's a Cup car built by Lotus Sport, the factory's own high performance division, for racing. It has a full rollcage, harness bar and 4-point belts, safety equipment (electric kill switch and plumbed-in fire extinguisher system), Öhlins fully adjustable suspension, sintered clutch, limited slip diff, big brakes and a Bemani supercharger putting out around 270bhp (with a really good water-cooled intercooler system that keeps it cool and efficient). To keep the weight down it has no air con, no electric windows, and no ICE (the speaker covers just cover the holes)!
Apart from home cinema, I'm into a few other things including cars (real and virtual) and photography.
Going back on topic a little, I've only been using my home cinema for just over a week, but so far I'm really happy with it. Nothing I would want to change yet ... which is a relief and a sign too that the time I invested in researching what I needed was not altogether wasted. Also a relief because of the not insignificant fact that my wife thinks I've spent more than enough already - which I believe is not uncommon
Old 21-04-2009, 1:23 AM   #14
7,964, Level: 21
Points: 7,964, Level: 21 Points: 7,964, Level: 21 Points: 7,964, Level: 21
Thanks: Gave 29, Got 65
Nice room, after reading about your teufel speakers and how you like them,may have to see about getting a set of system 6 speakers. Did you change the colour of your sub thought they were black and silver can't really tell from your pictures.
do you have better pictures of the fronts and sub.
Old 21-04-2009, 7:59 AM   #15
Kenny Glasgow's Avatar
12,077, Level: 26
Points: 12,077, Level: 26 Points: 12,077, Level: 26 Points: 12,077, Level: 26
Thanks: Gave 71, Got 228
Great room, you must be delighted
Old 21-04-2009, 10:50 AM   #16
1,864, Level: 10
I actually bought the beech version (with silver sections) as the set in this colour was on special offer. I covered them and the silver left & right front speaker stands with stick-on black velvet
Last edited by inzaman; 21-04-2009 at 4:05 PM. Reason: Image breaks forum rule no. 9
Old 21-04-2009, 3:42 PM   #17
7,964, Level: 21
But this is what they look like if you order black:
Do you have a picture of your handy work
Old 21-04-2009, 4:28 PM   #18
1,864, Level: 10
I also gave the chrome "Teufel THX" badges a wash of Tamiya matt black acrylic model paint as I thought they were too distracting and couldn't remove them without endangering the surface of the speaker covers
homethx (21-04-2009)
Old 21-04-2009, 4:49 PM   #19
7,964, Level: 21
I'm going to be using that idea
Old 21-04-2009, 5:35 PM   #20
1,864, Level: 10
Now I'm not trying to break "Forum rule No. 14" – I'm just exercising free and open comment as fits a democratic society but as my post above has been altered by a mod for "breaking forum rule no. 9", in this thread, which was started by me, I feel it only reasonable to be allowed to state my position, whichs is as follows:
I seriously doubt if commercial organisations (as opposed to private individuals) find it negative to have pics of their products from their website added to a thread! On the contrary, I sure they're happy for their products to reach as wide an audience as possible!!!
For years, I've been on forums for all sorts of subject matter and I've NEVER had a post moderated anywhere else except here and this is the second thread where that has happened to me.
The point I'm making is that, if everywhere else on the net that I've been I don't get moderated, then perhaps the issue lies not with me but with a plethora of over-restrictive forum rules (that no-one else has) and over-zealous moderators who enforce them to the letter.
If one of the mods finds this unreasonable, please do NOT just delete this comment – delete the whole thread and I certainly won't even go near this forum again!
Old 21-04-2009, 7:13 PM   #21
Illustrious Member
Pecker's Avatar
43,925, Level: 51
Activity: 20.5%
Someone remind me where I can find the forum rules.
Steve W
Old 22-04-2009, 12:52 PM   #22
Conspicuous Member
eiren's Avatar
21,848, Level: 35
Points: 21,848, Level: 35 Points: 21,848, Level: 35 Points: 21,848, Level: 35
Activity: 37.5%
Activity: 37.5% Activity: 37.5% Activity: 37.5%
Thanks: Gave 1,253, Got 1,372
Rule 9 = You cannot link images from manufacturers websites:
Use images from 3rd parties' websites without their permission. Linking to an image on someone else's website without their permission is considered to be bandwidth theft. This is not a copyright issue but a bandwidth issue. We have had big problems with people linking to our images without permission and we don't allow members to do the same to other people.
AVForums.com AVForums rules
The simplest way around this is to just provide a link to their website with the product on it.
By the way, this is an awesome build. What a great cinema room! That's the reason I was in here, not the rules stuff above.
Keep up the good work with all the info and photographs.
Old 22-04-2009, 2:40 PM   #23
Illustrious Member
Pecker's Avatar
43,925, Level: 51
Activity: 20.5%
Right, thanks.
Easylistening, as it says that rule is there for bandwidth reasons. I find the easiest thing to do is to save the image to a photobucket account (or similar) and link to that.
Don't take it personally - it's just the rules, and I'm sure no harm is meant.
Love that cinema! Please keep posting.
Steve W
Old 22-04-2009, 3:11 PM   #24
14,423, Level: 28
Activity: 3.8%
Steve W
+1 to this. I'm trying to plan how to squeeze in a dedicated room (I might start a thread in the DIY with my floor plan and ask for suggestions...). Threads like yours are a great inspiration and help others.
Hope to see you back here again soon.
Old 22-04-2009, 8:58 PM   #25
1,864, Level: 10
The point is, firstly, that "bandwidth" will not be an issue on a commercial site – they want lots of traffic!
Now that is clearly not right! You are only supposed to add pics to photo sites that you own the copyright for. If you add pics owned by someone else, you are effectively passing them off as your own (whether that is your intention or not is irrelevant) thereby infringing copyright and certainly contravening the photo site's (legally-based) rules!
OTOH, linking directly to a firm's pic is like free publicity for them, as anyone can follow the URL and view their website – and that is my second point – that is what they have the images there for after all!!!
Consequently, IMO, applying "rule no. 9" to a pic linked from a commercial site when discussing their products(!!!) is quite ludicrous. It makes the thread less informative and therefore less useful for the forum members and it deprives the manufacturer in question from some free publicity.
Having the pic in the thread is a win-win situation (who is it supposed to harm?), whereas removing it is a lose-lose situation (exactly who is supposed to benefit)?
Please note that I am NOT demanding an answer from a mod (in contravention of "rule no.14") – I'm merely debating with fellow forum members the sense of applying rule no. 9 to pics linked from commercial sites. I suggest that this simply restricts the free and convenient flow of information and serves no-one!
I would emphasise once more that all this is in respect of pics from commercial sites – obviously the bandwidth argument can be a justifiable one for a private individual's site.
Particularly if a forum has loads of "rules", the onus has to be on the mods to interpret them sensibly... if I get "moderated" in future threads for what I, as a responsible adult, consider an unreasonable interpretation of forum rules a third time I will my membership – if I'm not already banned – but I'll shut up about it now and see how I fare
Thanks for all the compliments about my build. It's only when I look back that I fully realise just how much I did. I can remember being at certain stages and thinking, "Only need to do this and this now and then it's pretty much finished", but I tend to get caught up in the details once I have an idea.
For example, the Charlie Chaplin figure was originally a sort of bits and pieces stand.
Here's a pic of one in original condition and here's the link
Charlie Chaplin, Herrendiener, Original Butler Produkt - Altona Dekoration zu verkaufen - Kijiji Altona
Mine was a damaged, surplus to requirements one that a neighbour was throwing away. I immediately adopted him and had to fill in the various holes (under arm and where shelf had been). I soon decide to change it from mere painted wood to (black stick-on ) velvet for the hat – and then the clothes. And then decided that the dishevelled tramp look demanded a crumpled surface, so took several hours making him mildly 3-D to get the effect I wanted.
It's the little details that take time (unless you just go and buy stuff or have someone – paid or voluntary – to make things for you), but make these things make it more special for both the one who builds it and for the guests.
Old 23-04-2009, 11:59 AM   #26
3,718, Level: 14
Points: 3,718, Level: 14 Points: 3,718, Level: 14 Points: 3,718, Level: 14
Thanks: Gave 21, Got 55
Have you ever had to pay for hosting a busy site? Not posting hot linked images and bandwidth stealing is a common rule on most forums.
