New Build Advice Needed Please!
| | Post Reply |
| | #1 |
| Member | New Build Advice Needed Please! Advertisement Want to Advertise?
Hi All, I'm looking for a new home cinema setup, i have a budget of £2500 to which i will need to purchase the following: 1) 46" Plasma could go to 50" 2) Blu Ray Player 3) 5.1 Cinema surround setup (Would need wireless as the floor is Solid Wood) 4) Cables etc I have looked around and like the Panasonic range, but im not totally sure what to look for as this will be my 1st system Any advise given would be must appreciated Regards Stu |
| Quote |
| | #2 | |
| Member | Re: New Build Advice Needed Please! Quote:
Stu wireless speakers still need cables for power - you ok with this? | |
| Quote |
| | #4 | |
Latest G10 panny plasma here check out HDTV Reviews – LCD TV & Plasma Television Display Rating for latest review as they have a sd processing problem - only a problem on some programmes. match it with a panny bd player go for the onkyo receiver for 7.1 sound not into wireless speakers much - but my niehbour has got a kef system around 500 quids worth and it sounds awesome! hope this of some help - you could always blow your budget and get a pioneer kuro 9th gen plasma much better than the panny but alas 1800 quid. | |
| Quote |
| | #5 | |
so all my cash is tied there, i might be able to stretch again to £3000 but that would be the ultimate limit for now i could afford to spendIll have a look around at the links Again many thanks for the quick response ![]() Stu | |
| Quote |
| | #6 |
One last question for now, i current have a Samsung LE40M87BDX 1080p screen which i have been told has been replaced with a 100hz version, what is so great about the 100hz and does the new panny have it? What cables do i need to go for?? are gold plated terminals just a myth? Stu |
| Quote |
| | #7 | |
100hz is really for watching sports - it shoves in an extra interpolated frame between the already 50 per second therefore you're getting 100 pictures per second. this means more input lag - not a problem when watching TV but a major problem for gaming. I've got on my sony (called motionflow) and its great for watching sports. if you have it on with movies they look a litle more like video. the panny g10 has their version (intelligent frame creation) and would be essential for watching SD sports on a screem of this size. The smaller models tend not have it since its not as much of an issue on smaller displays. cables - i think QED provide best value for money - they sometimes make a difference - but i can't tell on mine between a £20 scart cable from sky + box and the one the sky + box came with.. I can tell, however, on my blueray player! let us know how you get on! good luck Dan | |
| Quote |
| | #8 | |
Ok so i have the equipment list now which is: 1) Panny P50G10 and slimline wall bracket 2) Panny BluRay Player 3) Sky HD 4) Kef KHT-2005.3 Black Cinema Sound Speakers 5) Cinema Amplifier is yet undecided 6) 3 * HDMI cables ( Either IXOS or QED ) 7) 5 Metre Power cable for TV 8) 2 * Optical audio cables ( Either IXOS or QED ) 9) Some form of cabinet to house the BluRay, Sky HD, Denon Amp Now i have a wall in the room which is plasterboard but has the strengthen beams running down it so i plan on putting the screen on the wall and having the cables running inside the wall from the TV to the cabinet. Question 1: How difficult is it to mount the TV on the wall including the plastering fitting the trunking and cables etc? I'm not very good when it comes to DIY and was thinking of getting this done professionally seeing as its a brand new house Question 2: I would like to wall mount the speakers also can i wall mount small KEF speakers directly into a plasterboard and i guess i should also run the cables for the speakers in the walls like the TV. Questions 3: I would like also to mount the centre speaker just under the TV again mounted on the wall with the cables running inside the wall is this possible? Question 4: shall i make it easy on myself and have the surround sound speakers on the floor facing up. Any advise on the fitting, mounting and cable location would be gratefully appreciated Regards Stu | |
| Quote |
| | #9 | |
Hi stu, looks like a class system! its similar to my neighbours set up, he's got a yamaha amp which give the base some right old welly - it also comes with a little mic that you put where your head is going to be and i sets up the spear volumes and delays for you. we had star wars two on it yesterday, the bit with the siesmic charges in the asteriod field and the sound was amazing - I thought it was going to pop the window out! you could put all the wires in the wall, with sheiled cables it should't affect picture quality. you may want to use ducts in the wall so you can change/repair/upgrade your kit without breaking out the wall. the yamaha amp will chuck out 7.1 sound which the panny blueray will provide so it will give you an even better sound experience. go for as big a screen as your budget and viewing distance will allow since your sound is going to be fantastic and your picture should be able to match it! wall mounting is straight forward as long as you've got the correct bracket. i'd keep the speakers pointed at your head instead of the ceiling since you could get some delay in the back. i'm genually excited for you - let me know how you get on! Dan | |
| Quote |
| | #10 | |
Thanks AGAIN for the info, ill have a look into the yamaha amp's right i need to find someone to help with the plastering now ![]() Stu | |
| Quote |
| | #11 | |
also will you be doing a floating wall? I also noticed that your went for an amplifier instead of a receiver :S quite odd but then again im no expert either.. i am too wanting to get the whole nine yard for a new build flat i just bought and quite short on cash. I was thinkin of wireless ceiling speakers so i won't have to do too many DIY but turs out there's still some sort of diy to do i. I believe it's sometimes best to take your time buy bits and bits (the best quality) rather than buying something just quick and as you know technology is soo advance that tomorrow your setup/equipment will need upgrade.. anyhow im just saying try to go to custom installer forum and you'll also get some inputs.. i have been advised to get a denon avr as the quality of sound is better and it's easier to setup..however ill go down some store and see for myself ![]() i wish you good luck in the project..ill check out everynow and then and see how you coppin.. im sure you'll get plenty help here, guys here are very helpfull..just like a family here ..well almost lol Last edited by DJMALLZ; 20-04-2009 at 10:59 PM. | |
| Quote |
| | #12 | |
Hello Mate Im not using a floating wall, as the house is brand new is would be a little silly to make the room smaller than it is already and to be honest with the wall as it is the beams will be more than enough to hold the TV, and the wall mounted speakers wont be a problem as they are light enough, i see your point about buying the expensive items which i might have to do with the AV reciever.... Stu | |
| Quote |
| | #13 | ||
A few thoughts below for you 1ceman Quote:
Regarding cables (without wanting to get into the ridiculously long debates that crop up on the cable forums) I wouldn't personally spend money on getting 'branded' HDMI cables. HDMI is digital so it either works or doesn't, you won't get any better quality of picture/sound by spending more on a cable. I got all of my HDMI cables from here (their standard range - 'premium HDMI cable') and they do the job perfectly: I know a number of other forum members have used them as well. There is a school of thought that says you should go for higher quality if you have a cable run of >5m, but you shouldn't need this unless your equipment is going to be a long way from your TV. For your receiver, remember to make sure you get enough HDMI inputs for the kit you are getting now and anything you may want in the future. Given your budget and the other kit you are looking at, I would say something like the Onkyo 606 would be perfect, and can be picked up new for under £400. I may be a bit biased as this is what I have, but it does a fantastic job running my kit (Panny plasma, KEF 5005 speakers, Sky HD, bluray etc) Quote:
Q2-4) Yes, this is all easily possible. Ideally mount the speaker brackets on a stud or noggin for extra strength, but the KEF 2005 speakers are not very heavy so should be possible to mount directly on plasterboard if you use the correct plasterboard fixings. I would not put the speakers on the floor facing up personally, for the extra effort it will both look and sound better to have them mounted on the wall. I would also put the speaker cables for these in the wall, if you're doing this with the cables for the TV then do it for the speakers as well, the finished result will look much better. If you're getting a plasterer in it won't cost any more for him to fill these holes as well. Hope that helps | ||
| Quote |
| | #14 | |
Hi Magslad Many thanks for your reply that has been most helpful 1 more question mind when you say just drill a hole in the wall then drop the cable in it then drill another to find the cable?I was actually thinking of using the same method as this chap: http://www.avforums.com/forums/home-...w-install.html But i guess this is alittle more specialised would be nice just to pay someone to come and just do this for me lolStu | |
| Quote |
| | #15 | |
You could always get a quote for someone to come and do the lot for you (especially if you're not good with DIY), but if you want to save a bit of money it's not hard to create some holes in plasterboard and run your cables, then just pay a professional plasterer to make it all look good again afterwards. | |
| Quote |
| | #16 | |
the only reason i wanted to use the chasing route was that i want to mount the rear speakers on the wall at the other end of the room, chasing would have made it easier.Maybe i look in the yellow pages for someone lol Stu | |
| Quote |
| | #17 | |
| Quote |
| | #18 | |
If you're in London I can get you someone, he won't charge loads and he's professional | |
| Quote |
| | #20 |
DONT USE YELLOW PAGES! Go with personal recomendations, Yellow Pages can be a recipe for disaster and over priced work. Good luck with your project |
| Quote |
| | #21 |
Morning All I havent posted for a while so i though i would post an update ![]() Nothing really has changed lol i'm moving into the house on the 29th May so then we can begin to rip apart a brand new house lol, anyways i have bought all the equipment which i got at a stonking price from my local Richer Sounds store in Reading, this is what i bought 1) Panny 50" G10 2) Onkyo 607 AV Reciever 3) Kef 2005.3 4) Panny 35 Bluray player 5) Panny Wall mount bracket 6) IXOS XHT458-100 HDMI cables 7) IXOS IXOS XHD308-100 Optical Cable 8) Cambridge audio speaker cable and mono cable for the sub Next up is a small AV Cabinet to house the bluray, sky hd and the onkyo AV I think we have a dry wall / brick main wall which means we are going to just drill a hole for the cables and run them down inside the wall rather than chasing out the wall as i dont think this is neccessary but we will see. I would looking to use the following plasterboard wall plugs but was wondering if anyone else had used them and if there where any problems with them: Toogler Plasterboard TV Bracket Fixing Pack - £6.97RS100 - TV, LCD, FLAT SCREEN, TFT, PLASMA WALL BRACKETS and MOUNTS Regards Stu |
| Quote |
| | #22 |
Well done (on both the house and the kit), must be very exciting. Remember to post lots of pics as you progress. Regarding the plugs, I don't have any personal experience of these. All I would say is that if I was wall-mounting a 50" plasma on a stud wall, I would make damn sure that the wall bracket was fixed directly into studs (and if necessary I'd put some more in to achieve this), rather than risk fixing it to plasterboard. |
| Quote |
| | #23 |
im sure the builder said to me that the wall is a solid brack wall with a small air gap then a plasterboard fixed to the brickwall, now im no brickie so im not sure if it has studs or not ![]() Anyways i was really only going to use the plugs for the surround speakers as my intentions where to cut away the plasterbaord then drill in a solid wood block directly into the brickwall then bolt the wall bracket into the solid wood then tidy up making it nice and neat, does this sounds feasible? Stu |
| Quote |
| | #24 |
Ah OK, I misunderstood. For the speakers, something like those fixings should be fine as you haven't got too much weight to hold up. If the wall you're mounting the plasma on is a plastered solid brick wall, then no problem. What you're suggesting would be fine, or just mount the bracket directly on the plastered wall as long as the fixings are going right through into the brick. |
| Quote |
| | #25 |
eh up stu, looks like its going to be mint set up! your wall is whats called dib and dab - the plaster board is 'stuck' to the wall with dabs or splodges of wet plaster which is why you get a 10-20mm gap at the back. you should be able to drill through the plasterboard and fix directly into the wall. the toggle things are ok but it is better to get into the stud if you can with just screw - it'll be a much smaller hole and less messy good luck - can't wait to see the pics. Dan |
| Quote |
| | #26 |
Hey Dan I have all these lovely boxes sitting around waiting to be opening its killing me lol, i guess all i have to do is locate the splashes of plaster so i can avoid these when putting the speakers up and running the wires in the walls now for the Plasma bracket you say dont cut a big hole? do you mean just drilling through the plasterboard wall and stright into the brick wall behind? if so im going to need some long arse bolts etc Any links to what i need to buy? Stu |
| Quote |
| | #27 | |
your best bet to buy them is Jewson or screwfix (here) | |
| Quote |
| | #28 | |
Once again thanks Dan you are a fountain of knowledgeStu | |
| Quote |
| Post Reply |
i did expect the to have there own power feeds
E. & O.E.
LinkBack URL
About LinkBacks
