Originally Posted by TenaciousJohnny Hi,
I've added my new socket to the mains ring & it works. Thanks for the advice everyone.
Re. Mr Oops question, about his quote, seeing what I had to do, I would have been happy to pay £200. I have solid brick walls. I had to create the hole for the new socket, lift a floorboard for the junction box, & create channels in the plaster.
TIA
Johnny |
Unfortunately, JB under floorboards does not comply with the wiring regs as all screw terminal connections have to be accessible for inspection and test (yes I know the regs are not statutory).
That's why it's better to spur off the ring from an existing socket, or to extend the ring between two existing sockets. You can also replace a single socket with twos ingle sockets on a dual back-box and the extend the ring from there, if there is no other convenient socket to get the other leg from.
Originally Posted by dave2506 My understanding of this mate is that as long as the cable is in a permitted zone (i.e. within a vertical or horizontal straight line from the socket) then capping is not required although is normally considered good practice for the reason outlined before. It is only if you choose to run a cable in a non-permitted zone (diagonally for example) that there are rules outlining how deep it must be buried and for capping etc.
Hope this helps! |
Regarding capping - capping is used to protect the cable during plastering, that's all. It does not provide sufficient mechanical protection for cables run outside the safe zones and buried <50mm deep (from either side of the wall!) - you have to use proper EARTHED steel conduit or cable such as SWA with earthed armouring. Even for cables in the safe zones, the 17th edition of the regs requires these to be RCD protected if buried less that 50mm deep (from EITHER side of the wall - though this is academic for 13A sockets anyway as all sockets <20A have to be RCD protectd regardless) though conduit etc is not then needed.
