Hi all,
I'm slowly (very slowly) progressing my cinema room and am now in the planning stages for my fabric-covered panels.
The panel construction is not a problem (already made a mock up which is okay for my application), but I'm a bit unsure about what kind of fabric to go with for the panels themselves.
I requested some samples from Camira fabrics, which seem to have an excellent range.
I've found a few sites that seem to like the Camira "Cara" range of fabrics for this kind of application. Mainly because they are acoustically transparent, so you can put your sound absorption/reflection material behind the fabric and have it actually take effect...
However, now that I have a sample, I'm not sure that I'm that impressed with the quality of the weave. It's very open and also very industrial.
The
kendal fabric they make is slightly less open, but looks a bit darker than the Cara EJ138 sample. It's definitely open enough IMO.
However, if I'm honest, I actually prefer their
Oxygen Inhale BA001 fabric, which is more suited towards seat covering rather than panels.
If I hold the Oxygen up to a window and try to stare through it, I can only just make out the light behind. In contrast, if you do the same with the Kendal you can easily see the window (and everything else) behind.
How important is it to have a very open weave for this kind of application? Am I crazy to consider aesthetics over function?
Are others using velvet for this purpose?
I'm just worried that I'm going to compromise the sound quality by picking something that looks good...
