Rope light
Old 07-02-2009, 8:55 PM   #1
hyb hyb is offline
1,904, Level: 10
Points: 1,904, Level: 10 Points: 1,904, Level: 10 Points: 1,904, Level: 10
Rope light
Well all i can say is damn you peeps have some mint home,s
Can anybody link me to the rope lights you all use?
cheers
Old 07-02-2009, 9:00 PM   #2
3,151, Level: 13
Points: 3,151, Level: 13 Points: 3,151, Level: 13 Points: 3,151, Level: 13
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 46, Got 21
Re: Rope light
Most of us seem to find that TLC are very reasonable. Don't forget that you'll need the mains connection kit and the mounting strip or clips (the strip gives you a better and more even fix)
Duralite Rope Lights
Also, when you do put it up, make sure you get all the bulbs pointing out - maybe a simple tip but will make a difference to amount of light you get and how even the light distribution is.
Old 08-02-2009, 11:55 AM   #3
8,677, Level: 22
Points: 8,677, Level: 22 Points: 8,677, Level: 22 Points: 8,677, Level: 22
Thanks: Gave 2, Got 110
Re: Rope light
try Hafele, they have just introduced a new range which come on 5m and longer lengths
Old 08-02-2009, 2:55 PM   #4
1,615, Level: 9
Points: 1,615, Level: 9 Points: 1,615, Level: 9 Points: 1,615, Level: 9
Thanks: Gave 0, Got 2
Re: Rope light
Try this site have got some good rope lights,
SMT / SMD Light Strips - by Ultra Leds U.K
Old 08-02-2009, 8:27 PM   #5
hyb hyb is offline
1,904, Level: 10
Re: Rope light
Cheers lads now i no where to get em from
Next question is do you fit a dimmer or what? cant work out how this chap has diff colour/brightness??
http://www.avforums.com/forums/home-...l-build-7.html
Thx again chaps
Old 14-02-2009, 8:59 PM   #6
3,151, Level: 13
Activity: 0.8%
Re: Rope light
Probably the easiest way of dimming the rope light, and I'll stand corrected by others, is to buy the home easy remote socket set and an additional dimmer (or just the dimmer and remote separately) and do it that way. Have been told/read that you can wire them into a dimmer switch on your wall, but not my area of knowledge.
http://www.diy.com/diy/jsp/bq/nav/na...=1234645144040
Hope thats helps.
Greg
