corner false wall
Old 06-02-2009, 2:51 PM   #1
1,342, Level: 8
Points: 1,342, Level: 8 Points: 1,342, Level: 8 Points: 1,342, Level: 8
Activity: 3.9%
Activity: 3.9% Activity: 3.9% Activity: 3.9%
Thanks: Gave 8, Got 8
corner false wall
Well after getting my first fix of these forums over the xmas hols i now find myself addicted and visit every day. after much reading the time has come to do my own little project. i will be purchasing a sony kdl 46w4500 screen and already have a 5.1 system . i have done a sketch and would like your opinions, i am a bit concerned about the right speaker position being set back from the corner of the chimney breast but do not really want to bring the wall any further out. i will be building recessed shelving for my equipment but have not put this in the sketch, if any one has any ideas how i can jazz it up a bit please fire away. by the way the room is 4.6 x 3.3 into the alcoves . look forward to your opinions.
Andy
Old 06-02-2009, 3:26 PM   #2
Indecisive's Avatar
3,035, Level: 12
Points: 3,035, Level: 12 Points: 3,035, Level: 12 Points: 3,035, Level: 12
Thanks: Gave 33, Got 26
Re: corner false wall
Hi, can I just ask why you don't just fix the TV to the wall opposite your sofa?
Old 06-02-2009, 4:58 PM   #3
1,342, Level: 8
Activity: 3.9%
its where the fire place is, did not draw that either lol
Old 08-02-2009, 10:48 PM   #4
1,342, Level: 8
Activity: 3.9%
This is my set up at the moment
Andy
Old 09-02-2009, 3:30 PM   #5
1,615, Level: 9
Points: 1,615, Level: 9 Points: 1,615, Level: 9 Points: 1,615, Level: 9
Thanks: Gave 0, Got 2
If you search the DIY forum for floating and false walls there was a couple of people who built units into the corner like your proposal.
It'll take up too much of my life to find them but give it a go there are a couple of good examples.
good luck.
andy900uk (09-02-2009)
