Cable pass trough wall plate
Old 25-01-2009, 12:38 AM   #1
1,404, Level: 8
Points: 1,404, Level: 8 Points: 1,404, Level: 8 Points: 1,404, Level: 8
Thanks: Gave 11, Got 9
hi all
i have put my infocus x9 on the celing and now i want to hide cables inside ceiling so i will need something to look prety for that holes. As i see sometime in ebay some plates i try to search for them and find some like this
Dual, Double Gang Bundled Cable Wall Plate, White - eBay (item 270284610126 end time Feb-04-09 14:59:39 PST)
but the seller don t post outside USA, and for it wants 16USD, and i think is too much for it plus 2x4usd
so i would like to get some help to get 2 units like this the less expensive possible and as i am from Portugal it will need to be a store to post to me or ebay or something close to it or if some one of you guys would like to sell 2 units i will apreciat
also to let know i want the ones that the hole goes out andd not to be inside the wall, that i see many time i want something like the one in the link to pass VGA, hdmi, RGB, RCA and power cables so it should be a double gang i guess, never see one before
would apreciat your replys
Old 25-01-2009, 1:08 AM   #2
2,026, Level: 10
Points: 2,026, Level: 10 Points: 2,026, Level: 10 Points: 2,026, Level: 10
Re: Cable pass trough wall plate
Maybe something like this...
Inverted Pass Through Bundle Cable Wall Plate Dual Gang
Old 25-01-2009, 1:20 AM   #3
1,404, Level: 8
right
but the images look the one that the hole goes inside wall and i want it to go out
do y know how much to post to europe??
tanks
Old 25-01-2009, 1:40 AM   #4
1,404, Level: 8
they charge about 30usd...wich is too much but is that kind of product
Old 25-01-2009, 2:50 AM   #5
3,214, Level: 13
Points: 3,214, Level: 13 Points: 3,214, Level: 13 Points: 3,214, Level: 13
Thanks: Gave 20, Got 35
Buy an av receiver and just pass through the hdmi and power and make smaller holes
Old 25-01-2009, 1:42 PM   #6
Conspicuous Member
Gary Lightfoot's Avatar
27,928, Level: 40
Points: 27,928, Level: 40 Points: 27,928, Level: 40 Points: 27,928, Level: 40
Activity: 18.2%
Activity: 18.2% Activity: 18.2% Activity: 18.2%
Thanks: Gave 42, Got 519
I used a downlighter ring that I had spare and passed the cables through that (without the lamp in place of course).
Or you could use a standard single pr double gang blanking plate and drill/cut a hole large enough for the cables you want to go through it. Even a letterbox draught excluder would do the trick.
Gary
Old 06-02-2009, 12:18 AM   #7
2,721, Level: 12
Points: 2,721, Level: 12 Points: 2,721, Level: 12 Points: 2,721, Level: 12
Thanks: Gave 2, Got 3
A similar thing has been talked about recently ... and only the other week I saw them myself in Wickes.
See Cable Brush Plates
Old 06-02-2009, 2:27 PM   #8
1,366, Level: 8
Points: 1,366, Level: 8 Points: 1,366, Level: 8 Points: 1,366, Level: 8
Activity: 1.0%
Activity: 1.0% Activity: 1.0% Activity: 1.0%
Thanks: Gave 37, Got 5
am not sure if this would be any good for what you want
Burst Brick Coax Cable Entry Cover Sky HD/Plus White on eBay, also, Aerials, TV Accessories, Consumer Electronics (end time 03-Mar-09 18:45:25 GMT)
or maybe you could make 1 with some fiberglass mat you buy for building boats or repairing car bodys. make a mould to the shape you want and then just apply the fiberglass and resins over it and you can make the cover any shape you want.
