Temporarily mounting speakers... how?
Old 22-01-2009, 9:12 AM   #1
2,761, Level: 12
Points: 2,761, Level: 12 Points: 2,761, Level: 12 Points: 2,761, Level: 12
Thanks: Gave 50, Got 13
Okay I admit that i'm a total DIY noob, but I was just wondering if there is an easy way for me to temporarily mount my side and rear speakers, so I can test them in different positions before I decide on their final positions.
My walls are all flimsy(ish) plasterboard, so I'd rather not make 101 holes all over the place, as it's a nightmare to re-patch it all up
I thought about tripods, but that's not really feasable as one of the heights I wanted to test, is about 2 metres from the ground (plus i'd need 4).
Any help or advice would be gratefully received!
Old 22-01-2009, 10:15 AM   #2
dj-dulux's Avatar
4,381, Level: 15
Points: 4,381, Level: 15 Points: 4,381, Level: 15 Points: 4,381, Level: 15
Activity: 2.3%
Activity: 2.3% Activity: 2.3% Activity: 2.3%
Thanks: Gave 10, Got 132
Re: Temporarily mounting speakers... how?
Those telescopic dry walling clamps may be OK. You could probably hire them for a weekend from hire company.
Something like these. You would have to make a clamp to hold the speakers.
Dupe...
Old 22-01-2009, 12:04 PM   #3
6,583, Level: 19
Points: 6,583, Level: 19 Points: 6,583, Level: 19 Points: 6,583, Level: 19
Activity: 1.5%
Activity: 1.5% Activity: 1.5% Activity: 1.5%
Thanks: Gave 516, Got 76
Just go down your local super market and get a load of cardboard boxes - cheap easy and no mess.
Or get 50 Argos Books - the new one is out now
Old 22-01-2009, 12:29 PM   #4
3,140, Level: 13
Points: 3,140, Level: 13 Points: 3,140, Level: 13 Points: 3,140, Level: 13
Thanks: Gave 3, Got 10
Have you got four tall friends?
Old 22-01-2009, 5:11 PM   #5
2,761, Level: 12
Not patient ones lol
Thanks for the suggestions, i'll have a look at my local Screwfix... if not then i'll see how many boxes I can nab from my local Sainsbury's
