Fake Chimney Breast with Kef Oval Speakers Question
Old 15-01-2009, 1:07 PM   #1
2,506, Level: 11
Points: 2,506, Level: 11 Points: 2,506, Level: 11 Points: 2,506, Level: 11
Thanks: Gave 40, Got 9
Hi all
I'm after a bit of advice...
Can anyone tell me how I could cut out the oval shapes on the plasterboard for the Kef 1005 speakers so they can be plastered and look perfect, I have everything flush the only issue is the speakers. Has anyone done thing before?
Alternatively can anyone tell me if it is possible to buy a black smallish rectangular speaker grill so I could get a square hole cut out and just put the grill over so you would not be able to see the gaps from the oval speaker.
Old 15-01-2009, 1:40 PM   #2
3,718, Level: 14
Points: 3,718, Level: 14 Points: 3,718, Level: 14 Points: 3,718, Level: 14
Thanks: Gave 21, Got 55
Re: Fake Chimney Breast with Kef Oval Speakers Question
Did the speaker not come with a template? For cutting the hole i would use/make a template and carefully cut around it with a pad saw.
