My "Budget" Setup / kinda fake wall...ish..
Old 11-01-2009, 2:51 AM   #1
2,283, Level: 11
Points: 2,283, Level: 11 Points: 2,283, Level: 11 Points: 2,283, Level: 11
Thanks: Gave 12, Got 3
Hey every one have been checking out some very nice posts on here of some of the pritty savage rooms people have designed and thought id give it a go.....Now its nothin compaired to some of the stuff here (be gentle im not a carpenter ha) but I said id throw it up any way to show what kind of ideas ive got from here...props to paddy also for the structure of his http://www.avforums.com/forums/home-...t-attempt.html
well i started of with my room like this bit of a mess i know...
Old 11-01-2009, 2:54 AM   #2
2,283, Level: 11
Re: My "Budget" Setup / kinda fake wall...ish..
so i started to build a frame out of 2x1 1/2 battons which took a bit of trial and error....
Old 11-01-2009, 3:04 AM   #3
2,283, Level: 11
after the frame was built i inserted shelves using 3/4 inch MDF for support. I also used 1/2 inch MDF on the front as I didnt want to use plasterboard because I didnt want to go down the line of plastering. I measured everything and cut the holes out of the front sheet and because I dont have the skills to cut a straight line I decided to use door paneling to frame my tv and shelves to house my amp,xbox,etc... also added a desk on the left hand side to support my monitor( cannot see in the pics but I have made a shelf for my pc under the center speaker to the right.)
Old 11-01-2009, 3:08 AM   #4
2,283, Level: 11
so after finishing the framing (well almost, ran out of wood ) this is what I have done to the fake wall/housing with all my gear in it.
Old 11-01-2009, 3:16 AM   #5
2,283, Level: 11
I had another 4 foot to the left of the unit so I decided to attach a worktop and shelves to hold my decks and records.so this is it so far still have to finish the trim on the front and attach a side panel with a door to get at plugs and what not and then to paint it. I also have to box in the shelves so you cannot see the wires at the back. will post more when finished. criticism welcome
Old 11-01-2009, 8:46 AM   #6
6,709, Level: 19
Points: 6,709, Level: 19 Points: 6,709, Level: 19 Points: 6,709, Level: 19
Thanks: Gave 35, Got 42
Hello
I like the look of what you have done there! A nice built in look. Only criticism would be to try and upload the pics to photobucket.
Great work tho
KobeoneHD
ohm-ed (11-01-2009)
Old 11-01-2009, 12:20 PM   #7
2,283, Level: 11
Hey KobeoneHD
Thanks for the comment really appreciate it.
Photos have been moved to photobucket
Old 11-01-2009, 5:28 PM   #8
4,328, Level: 15
Points: 4,328, Level: 15 Points: 4,328, Level: 15 Points: 4,328, Level: 15
Thanks: Gave 50, Got 45
Mate that looks brilliant !!!
I love the architrave [sp?] effect you've done and the shelf with your decks on is a great idea.... one which I may nick too!!
Top work
ohm-ed (12-01-2009)
Old 12-01-2009, 11:49 AM   #9
2,283, Level: 11
Nice one Paddy
ya the architrave works out well to cover any cuts gone pare shaped.
Its nice to finaly have my records sorted out and every thing on one wall makes it much more easier to manage.
Nick away......
Old 12-01-2009, 2:25 PM   #10
2,372, Level: 11
Points: 2,372, Level: 11 Points: 2,372, Level: 11 Points: 2,372, Level: 11
Activity: 1.7%
Activity: 1.7% Activity: 1.7% Activity: 1.7%
Thanks: Gave 23, Got 20
lovely m8, only critisim i got really is that the pictures dont do it justice, other than that its great
ohm-ed (12-01-2009)
Old 12-01-2009, 9:18 PM   #11
2,283, Level: 11
hey thecolonel,
Ya the pics are a bit dodge because I used my I phone to take them as it was in my hand at the time will post higher res pics when finished but thanks for the comment
Old 30-06-2009, 1:26 PM   #12
2,283, Level: 11
Hey lads well finished my room...I know the quality is bad but i bust my camera a few weeks ago...
also the top corner of the unit must be screwed back on as i was running wires threw alcoving(sp?)
Old 30-06-2009, 1:34 PM   #13
4,328, Level: 15
Top work fella! Looks brilliant and what an awesome solution
ohm-ed (01-07-2009)
Old 01-07-2009, 9:41 AM   #14
2,283, Level: 11
Cheers Paddy nice to have everything organized rather than falling over it!
Old 01-07-2009, 12:05 PM   #15
1,942, Level: 10
Points: 1,942, Level: 10 Points: 1,942, Level: 10 Points: 1,942, Level: 10
Thanks: Gave 9, Got 3
Nice work
ohm-ed (07-07-2009)
Old 07-07-2009, 3:55 PM   #16
2,283, Level: 11
cheers m7cky
Old 08-07-2009, 7:51 PM   #17
jt2k6's Avatar
1,028, Level: 7
Points: 1,028, Level: 7 Points: 1,028, Level: 7 Points: 1,028, Level: 7
Thanks: Gave 6, Got 7
V.V nice,
not a critisism, just a thought, would be nice to have the TV on a turntable, and have a second "window" facing the decks so you could see the TV when using them!, still some blinding work, and inspiration for mine
thanks
ohm-ed (09-07-2009)
Old 09-07-2009, 4:49 PM   #18
2,283, Level: 11
Thanks Jt2k6.. Not a bad idea at all maybe buy a cheap monitor and hook it up so i could have two screens....not a bad idea at all could use serato instead of hooking up my laptop...
Old 09-07-2009, 4:55 PM   #19
Kryptix's Avatar
13,360, Level: 27
Points: 13,360, Level: 27 Points: 13,360, Level: 27 Points: 13,360, Level: 27
Thanks: Gave 115, Got 267
Nice work mate!
ohm-ed (16-07-2009)
Old 16-07-2009, 10:51 AM   #20
2,283, Level: 11
Originally Posted by Kryptix View Post
Nice work mate!
Cheers Kryptix will try and get some hi res photos up soon
