Wall case for cables to feed through?
Old 07-01-2009, 12:27 PM   #1
6,605, Level: 19
Points: 6,605, Level: 19 Points: 6,605, Level: 19 Points: 6,605, Level: 19
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 158, Got 74
Hello all i've seen in some peoples threads but can't remember which ones, they chase cables into or behind a wall and when fed back through the wall have used a white plug like surround.
Could someone please put me in the right direction as to where to get one from?
Cheers.
Old 07-01-2009, 2:08 PM   #2
2,363, Level: 11
Points: 2,363, Level: 11 Points: 2,363, Level: 11 Points: 2,363, Level: 11
Thanks: Gave 7, Got 5
Re: Wall case for cables to feed through?
You mean these sort of things?
http://www.diy.com/diy/jsp/bq/nav/nav.jsp?action=detail&fh_secondid=9290740&fh_view_ size=6&fh_eds=%3f&fh_location=%2f%2fcatalog01%2fen _GB%2fcategories%3C{10082}%2fcategories%3C{8960089 }%2fspecificationsProductType%3dconduit&fh_refview =lister&ts=1231337042768&isSearch=false
I'm just going to use normal electrical ones as they're about 50p a box from B&Q and would just need a holes cutting in!
Old 07-01-2009, 3:36 PM   #3
6,605, Level: 19
Activity: 0.8%
not quite but it's that sort of case but has a black letter box style material in it?
Old 07-01-2009, 3:49 PM   #4
3,988, Level: 14
Points: 3,988, Level: 14 Points: 3,988, Level: 14 Points: 3,988, Level: 14
Thanks: Gave 5, Got 8
Cheers.
Do you mean like this
Aldous Systems (Europe) Ltd Brush Faceplates
Also reading the link they also have them on the wickes website so not sure if they might have them instore.
good luck
Dave
thelegendofyrag (07-01-2009)
Old 07-01-2009, 3:58 PM   #5
6,605, Level: 19
Activity: 0.8%
there the ones excellent.
Thanks Dave
Old 07-01-2009, 7:30 PM   #6
6,377, Level: 19
Points: 6,377, Level: 19 Points: 6,377, Level: 19 Points: 6,377, Level: 19
Thanks: Gave 14, Got 38
You can get them from Wickes also, which may be easier if you have a local branch:
single gang
or
double gang
Old 07-01-2009, 7:41 PM   #7
6,605, Level: 19
Activity: 0.8%
thanks mate the link was in his link. have a thanks anyway.
