Originally Posted by deansocial I see it like this, if i can screw a kitchen unit up which is held with 4no 3" 10s then that unit which on its own weighs 30kg +- then it is filled with tins of beans etc and stays on the wall i'm sure 10 screws in a wall bracket will hold more than well enough. |
The difference being that the kitchen unit weight is spread over a much bigger area both size wise and pressure wise (i.e. surface area) compared to a wall mount which is much, much smaller in size with lots of surface area missing within the mount. This also means that a mount is likely to have more fixings per block. Also, a plasma/LCD mount may be a cantilever altering the stress massively when extended and moved etc.
I've ordered my Rigifix mounts from Mark Grant off here
6 Rigifix mounts (each tested to 105Kg!) delivered for less than £10... do you really want to bother cutting out plasterboard at these prices?
Do a search for 'Rigifix' and read all the posts like I did - you wont find a single post where the rigifix user wasnt happy! One guy hung off his mount after using them and he weighs over 20 stone and it didnt go anywhere LOL! The best thing too is, should you ever wish to move the mount, after pulling the Rigifix's out, all you will have to do is use some filler on 6 plasterboard holes!
