Rope Light ADvice.
Old 30-12-2008, 10:01 PM   #1
stuart1976's Avatar
6,666, Level: 19
Points: 6,666, Level: 19 Points: 6,666, Level: 19 Points: 6,666, Level: 19
Thanks: Gave 55, Got 181
Rope Light ADvice.
Hi Guys
I'm after some rope lights and I'm sure I've seen some where they can be cut to the length required, but for the life of me can't remember where.
Anyone on here know?
Old 30-12-2008, 10:55 PM   #2
8,104, Level: 21
Points: 8,104, Level: 21 Points: 8,104, Level: 21 Points: 8,104, Level: 21
Thanks: Gave 25, Got 91
Re: Rope Light ADvice.
Duralite Rope Lights
stuart1976 (31-12-2008)
Old 13-02-2009, 11:51 AM   #3
stuart1976's Avatar
6,666, Level: 19
Originally Posted by MitsiTurbo View Post
Thanks Mitsi. Can these be connected to the wall switch rather than using the mains plug?
Old 13-02-2009, 5:29 PM   #4
8,104, Level: 21
Yep, dimmable to. Ive got all my ropelights connected into wall dimmers but will eventually be going to Lutron, Mode or Rako controllers. To connect them to the light switch, you need to do it by connecting directly to the switch
or using 1.5mm2 twin and earth to where the ropelight 'starts' and join using a junction box (if it will be accessible) or mechanical crimps (if not accessible).
Hope this helps!
stuart1976 (13-02-2009)
