Kids Bedroom
Old 29-12-2008, 8:27 PM   #1
10,692, Level: 24
Points: 10,692, Level: 24 Points: 10,692, Level: 24 Points: 10,692, Level: 24
Thanks: Gave 54, Got 18
Kids Bedroom
Ok so now im starting on the Kids bedroom this week heres a lists off the to do's and hopefully ill get the pictures up for ur comments and advice along the way.
(1) There is no areil point in the room so ive got to get a feed of the main areil into the room.
(2) Ive got to wall mount the kids xmas present of a 16" Lcd with DVD player built in on the wall.
(3) Ive got to get the kids Nintendo Game Cube hooked up to it aswell.
(4) Ive got to Connect the pc in the office to the kids tv.
Then after all thats done ive got to decorate aswell!
Old 29-12-2008, 8:32 PM   #2
3,255, Level: 13
Points: 3,255, Level: 13 Points: 3,255, Level: 13 Points: 3,255, Level: 13
Thanks: Gave 38, Got 50
Re: Kids Bedroom
You might have better luck posting here Home Cinema DIY - AVForums.com
Old 30-12-2008, 7:46 AM   #3
Moderator/Reviewer
mabo's Avatar
22,390, Level: 36
Points: 22,390, Level: 36 Points: 22,390, Level: 36 Points: 22,390, Level: 36
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 1,145, Got 939
Re: Kids Bedroom
Moved to Home Cinema DIY - you'll be more likely to get the relevant advice here.
ajwatson (01-01-2009)
Old 01-01-2009, 11:44 PM   #4
10,692, Level: 24
Re: Kids Bedroom
So weve cleared the room, and the mrs has finally agreeded on the Tv's flaming location, she wanted to see it drawn on the wall!! So tomorrow we make holes!
Old 02-01-2009, 10:00 PM   #5
10,692, Level: 24
Re: Kids Bedroom
Todays effort went like this!
Big thanks to billtk11 for the help sorting this out, people from the mids need to check out www.homeav1.co.uk
Kids Bedroom-02012009561.jpg   Kids Bedroom-02012009563.jpg   Kids Bedroom-02012009564.jpg   Kids Bedroom-02012009565.jpg   Kids Bedroom-02012009567.jpg
billtk11 (04-01-2009)
Old 04-01-2009, 5:16 PM   #6
6,291, Level: 18
Points: 6,291, Level: 18 Points: 6,291, Level: 18 Points: 6,291, Level: 18
Thanks: Gave 16, Got 2
Re: Kids Bedroom
Thanks for the ad! make sure you post your finished pics looking foward to seeing the room all done
Old 04-01-2009, 6:12 PM   #7
10,692, Level: 24
Re: Kids Bedroom
ok were done sort of lol, ive got to just finish of the mood lighting to the shelves behind the bed and paint the filler in but heres more pictures.
Old 05-01-2009, 7:48 PM   #8
10,692, Level: 24
Re: Kids Bedroom
Finished the Kids Tv wall & mounted the lighting to the floating shelf above the headboard now all ive got to do is chase the wires. Kids finding it hard to switch the swith under the bed am considering hiding the wires behind wall and getting them on remote.
Any ideas on the best kit to buy to do this?
