Help with wall plates
Old 23-12-2008, 10:41 AM   #1
2,282, Level: 11
Points: 2,282, Level: 11 Points: 2,282, Level: 11 Points: 2,282, Level: 11
Thanks: Gave 6, Got 7
Hope you can help me with my so far fruitless search! I'm currently upgrading my TV distribution for my house and as such need a wall plate for where the aerial terminates in the living room. I've been looking for one that has 2 aerial sockets (1 labelled "TV" and the other "Return").
I know I can get one that has F connectors on it as well but I just need a wall plate with the connections mentioned above.
If anyone can advise as to where I can get one (if indeed one exists!) it would be most appreciated.
Old 23-12-2008, 11:30 AM   #2
3,553, Level: 14
Points: 3,553, Level: 14 Points: 3,553, Level: 14 Points: 3,553, Level: 14
Thanks: Gave 6, Got 6
Re: Help with wall plates
Dave, I got something similar from CPC, they are modular so you pick nd choose what outlets you want. Think they also had standard wall sockets. This what you are after?
UNBRANDED|CBBR0467 CBBR0472|DOUBLE FLUSH WALL PLATE-NON ISOLATED | CPC
dave2506 (24-12-2008)
Old 24-12-2008, 3:57 PM   #3
2,282, Level: 11
Yes that's exactly what I'm looking for in terms of functionality - I just wondered whether you could get one that has each socket labelled as "TV" and "Return". Just to avoid any future confusion as each socket performs quite a different function!
