Originally Posted by Gee Hi Mitsi,
Hi Quantas,
I had a look at your little project; very impressive! Your star ceiling is exactly the kind of thing I'm after (only mine will be a fair bit smaller); where did you get your kit from and how much was it if you don't mind me asking?
Cheers, |
Hi Gee,
I got my kit from Starscape, a very helpful two man operation, ask for John he knocked a wee bit off as well and sent me an xtra motor and a couple of transformers so I should be set for life
Word of warning though, they are not "dimmable" straight out of the box they require a wee bit of modification to work through a varilight IR wall switch. I can tell you how I did it if you PM me.
I've put some hours into it and its not their yet but the ceiling looks the dogs and Very Definitely worth the effort and swearing.
Please feel free to contact me and I can point out the mistakes I made which ate time up to get round them.
Forgot to mention how much, I had 400 tails made of varying lengths from 1m to 3.5m and the pack cost me about £350.
Russ
