Ok so I bought a house in the middle of the credit crunch, so what! I may be in negative equity already but you can beat a bit of retail therapy.
I moved in at the beginning of August and swiftly decided I wanted the TV on the wall. The main reason for this is that my lounge has two doors/walkways and I didn’t want to traipse cable along the floor or under a mat. A dramatic approach to solve a small thing I know but then I thought ‘proper job!’.
I have to admit this forum gave me some great inspiration and ideas. And so it began. I already had a big 40” TV and didn’t want to get another just yet so planned on just upgrading the speakers. Here’s the kit:
TV: Samsung 40” LCD LE40N73BD
AMP: Denon AVR-3808
Speaker: KEF KHT2005.3
Other: Xbox360, Xbox (media center) and Sky+
Here’s how it started. I didn’t know what the walls were like so I did a little test patch:
My existing kit (with old speakers), on the wrong side of the room:
Thankfully my dad’s an installation engineer and so has plenty o’ tools I could borrow, one of them being a meaty chaser. I did intend on using conduit in the walls (probably 16x16mm for the rear channels) however when I started chasing it became apparent I wasn’t going to be able to fit it in on top of the brick. My dad thought I’d be able to chase some more of the brick out but when I tried it just wasn’t going to happen.
After what was probably half a day’s work I’d finished the channels. Of course I carefully planned where all the speakers were going to go before hand
. Those of you with a bit of nous will notice a fundamental issue with my cable routing. I’ll give you a hint: I intended on having the center speaker directly below the TV. From left to right:
Did you spot it? I’d run the channel from the TV point down to the floor directly instead of putting it to one side.
Even after I’d finished I hadn’t realised either, it wasn’t till the day before the plasterer was coming did I think about it, how stoopid am I!
Anyhow… I decided if I was going to get some nice new speakers I’d get some half decent cable to put into the wall. I got Chord Carnival Classic for the rears for about £3.30 a meter and Carnival silver screen for the center and fronts for £5.10. The nice people at
Cables and accessories for Hi-Fi and AV - divinecables.co.uk price matched the cables for me (and updated their website within an hour) so thanks to them! In total the cables came to £170 with banana plugs.
I wasn’t going to pay for termination as I’m a whizz with a soldering iron plus I got all the heat shrink to make it look as good as a professionals work. Here’s my first one and after an evenings work the whole lot terminated:
So the next step was to get the TV mount and stick the TV on the wall. I didn’t really have a clue what was best mount to use, I just knew I wanted to have the TV flush to the wall and didn’t want to spend a fortune on a uber swish one. After looking about I decided on an imount. I got one off ebay for £18. I cant tell you how pleased I am with it, its super rigid and comes with all the mounting bolts too (which I didn’t expect).
LCD TV Wall Bracket : Multi Monitor Desktop Mount : Flatscreen TV Stand : Imount.co.uk
Again I went to the dad for tools and borrowed his resin gun. I got some M8 bolts from B&Q and drilled the holes directly into the brick. Filled the holes half way with resin and then poked in the bolts. I put the mount on straight after putting the bolts in to make sure they were all in the right place. An hr or so later after it had dried and they were never coming out!
Of course I levelled the mount up and everything before hand but that goes without saying.
That evening I put the TV on the wall to see what it looked like….. brilliant!
So I’m about a day away from a week off work and 3 or 4 days off the plasterer coming. I needed to get all the cables in ready for him coming this week, today in fact! I started with rear cables, they went in ok but I was having trouble getting the cleats to hold the cable in the dodgy mortar, I persevered.
This is the point where I realised, oh no! I haven’t got the speakers and I haven’t thought about where the center is going to be mounted. As panic set in I thought the best thing to do was try and get hold of some speakers so I could make sure they cables and mounts were all ready. One call to Sevenoaks and no luck, best they could do was delivery in 4 days, next call was to Richer Sounds, yes! They had 1 set of 2005.3’s left and I was deteremined to have them. Sods law they were already reserved for someother guy
. Luckily they had a set on display so I went down in the hope I could remember what the mounting bracket was like so I could drill the holes ready. The uber nice man at Sheffield Richer Sounds (Richard the manager) then proceeded to a) take my hard earned for an ordered set and b) lend me a KEF egg to take home and measure up! I can’t thank him enough, he helped dig myself out of a hole! I even took some pictures in store so I could make some form of template when I got home. I know some people might be interested to see the bracket also as I searched all over the net!
So the day came where I needed to run the cables. I’d spent the week previous to this purchasing every type of cable under the sun for the TV to AMP run, here’s what I ran:
HDMI
Scart
S-Video
VGA
Kettle Lead
Optical
Ethernet (I fancy a series 7 or 8 Samsung next)
RF cable (satellite or aerial cable)
And this is what It looked like in a big fat loom:
My cleats weren’t holding fast in the crappy mortar so I needed to come up with a method of holding them down. After searching through the junk in the shed (both left by the previous owner) I found an aluminium carpet tred, you know the one which you would use in the door ways between carpeted rooms. I cut it into 3 or 4 inch lengths to make miniature battons, which I screwed with rawl plugs into the mortar, this held them all very firm
I used the egg from richer sounds to make a template which I could use to drill the speaker mounts. I used some medium weight use rawl plugs and screws with small heads for the mounts, these are solid as a rock. The only one I had issues with of course is the one directly below the TV where all the cables run. I managed to drill holes in between the cables and glued in the plugs, the screws are just sitting out ready for the plaster to go round them, wasn’t sure the plasterer would be ok with that?
To finish where the speakers were exiting I got a brushed steel letter box exit from Screwfix:
Brush Letter Plates Silver Effect 335 x 75mm - Screwfix.com, Where the Trade Buys
Here’s it all finished and waiting for the plasterer, you can see the center speaker screws just poking out.
