Originally Posted by HOF oh cr+p. I actually ordered and paid for a different cabin but that was what turned up. i ordered a 20 x 12 foot.
The company i ordered from has disapeared so was unable to get money back so i cut my losses and just got on with it. |
That's terribly bad luck..That size cabin would have been ideal..
How much will bass traps cost me?
That depends on what you use..
The cheapest way is to make them yourself..All you need is some semi-rigid fibreglass sheets, or some Rockwool and a simple frame and covering to fit them into..
I've made several myself, and they work well..
If you decide to go this route, I can help you with the making of them..
To buy commercially made traps can get expensive and they're no better than what you can make yourself..
and where can I get accoustic panels from?
Again..make them yourself..If you have any basic carpentry skills, you won't find it difficult..
I also made my own..
One more thing what is first and second reflection?
Reflection points are where the sound waves from the L & R front speakers, bounce off the side walls..
You can determine these points by having someone slide a mirror along a sidewall (level with the speaker) While you sit in the centre seat..
They move the mirror along the wall, from say the left speaker, until you can see the reflection of the speaker in the mirror..
This will be the first reflection point and is where you would place an acoustic panel..
Then they would continue sliding the mirror along the wall further, until you can see another reflection of the other speaker..
This is then your second reflection point..
I hope I've explained that clearly enough for you..Just let me know if there's anything that's not clear..
