Google sketchup :- tips?
Old 23-11-2008, 1:23 PM   #1
3,438, Level: 13
Points: 3,438, Level: 13 Points: 3,438, Level: 13 Points: 3,438, Level: 13
Thanks: Gave 0, Got 6
Im starting to use sketchup to plan my living room setup and not having a great time
Spent a couple hours mucking about but still not really got anywhere.
Anyone got any tips on how best to use it? Also if anyone can upload there sketch design's so i can have a play that would be great
Old 25-11-2008, 11:47 PM   #2
thefathacker's Avatar
1,922, Level: 10
Points: 1,922, Level: 10 Points: 1,922, Level: 10 Points: 1,922, Level: 10
Thanks: Gave 16, Got 3
Re: Google sketchup :- tips?
One tip. Seven words.
Watch some of the tutorial videos. Invaluable.
Old 26-11-2008, 7:42 AM   #3
yukichon's Avatar
16,571, Level: 31
Points: 16,571, Level: 31 Points: 16,571, Level: 31 Points: 16,571, Level: 31
Thanks: Gave 205, Got 153
Just like he said , go on 'youtube' and type in sketchup tutorial , infact just click this link YouTube - aidanchopra's Channel , he doea a dummies guide which i found brilliant
Old 26-11-2008, 12:51 PM   #4
vex vex is offline
10,364, Level: 24
Points: 10,364, Level: 24 Points: 10,364, Level: 24 Points: 10,364, Level: 24
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 27, Got 252
Think in terms of boxes and cubes not 2D rectangles and Squares and that helps imensley
V.
Old 26-11-2008, 9:12 PM   #5
THE_FORCE's Avatar
21,983, Level: 36
Points: 21,983, Level: 36 Points: 21,983, Level: 36 Points: 21,983, Level: 36
Activity: 12.6%
Activity: 12.6% Activity: 12.6% Activity: 12.6%
Thanks: Gave 1,653, Got 1,037
Also try importing some models from the warehouse and exploding them so you can see how other people have built them.
