Cable Help Please
Old 19-11-2008, 4:12 PM   #1
1,644, Level: 9
Points: 1,644, Level: 9 Points: 1,644, Level: 9 Points: 1,644, Level: 9
Thanks: Gave 18, Got 2
Cable Help Please
Hi there all!
This is my first post on here so please excuse me if anything I ask has been asked before.
I am looking to build a stud wall to house my LCD and hide the cabling in the wall.
I need some advice on what cables I need to put in the walll before I get started and re-plaster.
The equipment I have decided on is the following:
Samsung LE46A856
Denon AVR-2809 Av Receiver
Sony PS3 80GB
KEF KHT 1005.2
Denon ASD-1R iPod Dock
Any advice on cabling
Thank you in advance
Old 19-11-2008, 4:17 PM   #2
Conspicuous Member
21,526, Level: 35
Points: 21,526, Level: 35 Points: 21,526, Level: 35 Points: 21,526, Level: 35
Activity: 23.1%
Activity: 23.1% Activity: 23.1% Activity: 23.1%
Thanks: Gave 4, Got 1,393
Re: Cable Help Please
If your TV and Audio rack are close and next to or attached to the stud wall why not put a pipe in behind the stud. I my case I used 65mm PVC drain pipe which is great as over the past two years one or two cables have been changed, added, removed.
Old 19-11-2008, 8:06 PM   #3
1,644, Level: 9
Thanks for your reply but I was actually referring to what cables i would need to put into the wall?
Old 20-11-2008, 11:07 AM   #4
Conspicuous Member
21,526, Level: 35
Activity: 23.1%
I thought I answered that, put a tube in and then you are not worried about adding/subtracting cables at a later date.
My simple answer would be all the HDMI's, Scart and a component cable.
Audio from TV to AV system.
Aerial lead and mains connection.
