Originally Posted by Andy8421 Steve,
My post was tounge-in-cheek, but I am afraid I need to take you to task a little over your reply.
A 10% change in mains voltage will have a 10% change in unregulated DC level. The nominal voltage change for the lower voltage will be smaller, but 10% is 10%.
Too bad that don't make a tongue in cheek emoticon.
What is 10% of 230v? It is 23 volts.
What is 10% of 40V? it is 4 volts.
Is the result of those to calculations the same? Didn't think so.
But yes, if it falls 10% on the input, more or less, sort of, it falls 10% on the output. But you are passing though a step down transformer, so as illustrated, 10% on the input is not the same absolute number on the output.
And, that 4 volt loss in unregulated voltage is still within the reserve window that allows the 30v regulated voltage to continue on unaffected.
The part about Storage capacitor is right. But it is complicating an already complex matter. Because the caps are literally on the regulated output, indeed they do supply short term current, that eases the load on the actual regulated voltage, and that stabilizes the output voltage in the short term.
But if the capacitors are drained, then need to be refilled. Hopefully this happens during a period of lesser demand output load.
Personally, I suspicious of any line voltage filter that claims
"Voltage Stablization" unless I know what the internal workings are.
"Voltage Stablization" is a some what ambiguous term, and I would be leery until I knew exactly what was going on inside.
Steve/bluewizard
