Mechanical lcd tv stand
Old 06-11-2008, 1:53 PM   #1
cliocarl's Avatar
3,645, Level: 14
Points: 3,645, Level: 14 Points: 3,645, Level: 14 Points: 3,645, Level: 14
Thanks: Gave 6, Got 4
Hi guys,
obviously on shows like cribs you get to see lcds/plasmas appear out of units - ie they 'pop up' from a premade cabinet, or come down through the ceiling etc
I bought a 40" LCD but already have a projector that projects onto the white wall behind, problem is on the stand the LCD TV gets in the way of the image now and I was looking for a device which is relatively cheap ie say upto £200 perhaps that I can make the TV drop to floor level for when i want to view my projector.
Any ideas?
All help much appreciated
Old 06-11-2008, 5:22 PM   #2
vex vex is offline
10,367, Level: 24
Points: 10,367, Level: 24 Points: 10,367, Level: 24 Points: 10,367, Level: 24
Activity: 4.2%
Activity: 4.2% Activity: 4.2% Activity: 4.2%
Thanks: Gave 27, Got 252
Re: Mechanical lcd tv stand
Unfortunately, these just arent available at Sub £200.
The trade on some of the more reliable ones is well over £500.00
It might be worth looking at making one yourself, or spending the £200 on a projector screen to drop down infront of the screen instead.
V.
