Right, time for some pictures and more advice/opinions!!
Here's what I'm starting with, I used to have a two tier stand which held the centre as well (AE307), but a little while ago I went for the enclosed Besta unit and until I got the TV on the wall, the centre had to be put away
Anyway, excuse the mess!
So as I said, originally the plan was to move the rad from behind the TV, and put it onto the wall opposite the dining table/adjacent to the stairs, and mount TV on wall where it is, chase in cables, etc.
Wednesday SWMBO said she wasn't sure about moving the rad, heat going up the stairs, need to move thermostat, etc. She said about moving room around again, which we've been over before!!
Anyway compromising (she doesn't like the dining table in view when watching TV), I said only other real option would be to have TV at stairs, so maybe stud up a partition, hide AV stuff under stairs and mount TV on new wall. She said it sounded OK but couldn't imagine it, so last night I knocked up a very poor photoshop of how it could look!!
With just the banister line:
Wall to ceiling:
and with a little extension at end to give me more room?
Excuse the screenshots, a work colleague put those on without me knowing!!
The other half likes the first option best, but still isn't sure.
My main thoughts around it are where I would put my stuff with the TV and speakers taking up most of the room. I suppose I could sink them into the wall under the TV just leaving the fascias on display. Cooling isn't too much of an issue as I have a fan controller, etc. I have a Yam RX-V640, Sony DVP, 360 elite and soundbridge to house.
Other thing, what would be best issue with actually building the wall/banister? I was thinking of studding out the part under the stairs to meet the stairway, then maybe add a few more studs to banister and screw plasterboard to that. Or would I better ripping the banister down completely?
Trouble is, now the other half is undecided and says, well, just do what you were going to orignally!!??
I'm not sure, I'm not fussed about work but don't want to mess about with the stairway if it'll end up looking rubbish. Likewise, I see where she is coming from about the radiator, it will be quite close to the landing opening and may not offer much heat into the lounge.
Any opinions?
