Making use of my Loft as a Home Cinema
Old 28-10-2008, 11:29 PM   #1
itn itn is offline
itn's Avatar
3,091, Level: 13
Points: 3,091, Level: 13 Points: 3,091, Level: 13 Points: 3,091, Level: 13
Thanks: Gave 22, Got 5
Hi, I had my loft completed a couple of years ago, but didnt think of making it a home cinma at the time, was going to put a plasma in it instead. but, with prices being reasonable I would like to use a projector up there for sports, and a ps3, and stream hd videos via a LAN.
Here is my starting point:, and truth be told I done know where to start!!
See pictures below!!!
Window is a Velux M08 and placed lower for health and safety. I believe I can get blacckout blinds for this.
On viewing wall I have 2 double sockets either side, and on rear wall where we come up the stairs there is a double socket.
Whats your thoughts guys, help mucch appreciated....
Im looking at having a prjector, screen (if wall is no good), ps3, and a ntl digibox, and ill stream movies via ps3 from my htpc which is downstairs...
thanks
itn
Making use of my Loft as a Home Cinema-loft-home-cinema-001.jpg   Making use of my Loft as a Home Cinema-loft-home-cinema-006.jpg   Making use of my Loft as a Home Cinema-loft-home-cinema-007.jpg   Making use of my Loft as a Home Cinema-loft-home-cinema-009.jpg   Making use of my Loft as a Home Cinema-loft-home-cinema-010.jpg
Making use of my Loft as a Home Cinema-loft-home-cinema-011.jpg   Making use of my Loft as a Home Cinema-loft-home-cinema-012.jpg   Making use of my Loft as a Home Cinema-loft-home-cinema-014.jpg   Making use of my Loft as a Home Cinema-loft-home-cinema-015.jpg
Old 28-10-2008, 11:58 PM   #2
13,310, Level: 27
Points: 13,310, Level: 27 Points: 13,310, Level: 27 Points: 13,310, Level: 27
Activity: 3.4%
Activity: 3.4% Activity: 3.4% Activity: 3.4%
Thanks: Gave 343, Got 335
Re: Making use of my Loft as a Home Cinema
thanks
itn
It might be worth looking at 2.35:1 sreens given the room and you will need a lot of black velvet
Old 29-10-2008, 7:45 AM   #3
itn itn is offline
itn's Avatar
3,091, Level: 13
sorry to be a pain, can you explain further?... black velvet to darken room or for sound!!...room does get very dark with lights off...again room is carpeted.
what type of screen is that?.. i want to maximize the viewing area. I though I could just make the biggest rectangle and use that area.
Old 29-10-2008, 9:42 AM   #4
13,310, Level: 27
Activity: 3.4%
Firstly check this site out Projection Screens - Home Theater Projector Screens by Carada - FAQs There is a little talk about screen aspect ratio's
In simple terms TV's are now 16:9 (1.78:1) this is the normal aspect ratio for screens and HD displays. However films are usually 2.35:1 ot 1.85:1 ie narrower for the same width (black bars top and bottom)
One option if you are height restricted is to buy a screen that is 2.35:1 as you can fit a larger screen in and most films are this size anyway. The only bummer is that when you play 1.85: or 16:9 you will have to zoom your projector and refocus
Rgerarding black velvet. A fully light controlled room is step 1 stop ALL ambient light entering the room, Step 2 reduce light reflections in the room
Dark coloure and fabrics do the second step. The second step is as important as the first and makes a shocking difference, ever wondered why there are a lot of dark drapes and black/dark material in cinema's
Old 29-10-2008, 11:38 AM   #5
itn itn is offline
itn's Avatar
3,091, Level: 13
makes sense.... but how realistic is it to have drapes or curtains on the sides of the roof...doesnt look nice....
screen size ill have to look into?...
how much gap do you leave off the floor before the screen starts??? and what projector mount is reccomended for a wall and not a ceiling??
Old 29-10-2008, 11:44 AM   #6
Conspicuous Member
Gary Lightfoot's Avatar
27,928, Level: 40
Points: 27,928, Level: 40 Points: 27,928, Level: 40 Points: 27,928, Level: 40
Activity: 18.2%
Activity: 18.2% Activity: 18.2% Activity: 18.2%
Thanks: Gave 42, Got 519
I converted the loft for home cinema in my last house back in 2000 and initially had a 7ft wide 16:9 screen. I wanted to go wider but couldn't due to the ceiling slope which would put the screen on the floor. I Could go wider with a Cinemascope screen so then bought an anamorphic lens and made a 2.35:1 screen which was 8ft wide (16:9 was 6ft wide). I used a simple corded curtain track and black velvet curtains to mask down to 16:9 when not watching a scope movie (which wasn't often).
The screen wall was black carpet, and the walls below ear height were covered in grey carpet that was a close match to the rest of the room which was painted in Kodak 18% grey (to neautralise light reflections that would bounce of the walls and ceiling and end up back on the screen). Later I used some Maplin black felt speaker cloth to cover the walls and ceiling and that made a huge improvement to both the image quality (ANSI contrast doubled) and the viewing experience. I had previously used the speaker cloth to cover the speakers because I only like to see the image and not the equipment. With the black walls and ceiling you couldn't see anything except the image which I felt was much better.
You can use the zoom method to view scope movies rather than an anamorphic lens but that's a personal preference. Both have pros and cons, but if the pj has the zoom range that would be the cheaper option. I'd always recommend an anamorphic lens though.
There are some pics in my sig.
A rule of thumb for screen height is to have the eyes fall at around one third of the way up the screen when seated. In my last place my eyes were between a third and half way. The screen was around 18ins from the floor IIRC. Having a screen too hight can be uncomfortable to watch after a period of time and the eyes naturally want to fall lower than higher unless you're reclined.
Gary
Old 29-10-2008, 4:29 PM   #7
3,268, Level: 13
Points: 3,268, Level: 13 Points: 3,268, Level: 13 Points: 3,268, Level: 13
Thanks: Gave 1, Got 10
My attic setup might give you some ideas about equipment storage and cabling.
Mike's attic cinema and games room
I fitted a blackout blind to my Velux roof window - you will need the serial number off the window and then put it into their website. They aren't cheap but they are good.
I haven't painted the whole room black because I still use it as a room. I'm sure it would improve the picture if I did but as long as you can black it out completely, you will still get pretty good results.
Good luck with the conversion, it looks like a really nice space to work in.
Mike
itn (06-11-2008)
Old 30-10-2008, 11:46 AM   #8
4,708, Level: 16
Points: 4,708, Level: 16 Points: 4,708, Level: 16 Points: 4,708, Level: 16
Activity: 1.9%
Activity: 1.9% Activity: 1.9% Activity: 1.9%
Thanks: Gave 63, Got 83
just a quick question,
what is the height from the floor to the ceiling at the center? and what is the width and length of the room?
my loft is of similar dimensions and i'm trying to visualize what mine would look like should i convert it.
thanks
Old 30-10-2008, 6:09 PM   #9
itn itn is offline
itn's Avatar
3,091, Level: 13
Hi, thanks for reply, ill measure up tonight and post measurements later....
Old 01-11-2008, 12:09 PM   #10
itn itn is offline
itn's Avatar
3,091, Level: 13
Hi, sorry for the delay in my reply:
The height from the floor to the ceiling on the screen wall is height 191cm /75" and width is 335cm/132" or 11ft.
and width of room is 355cm or 11.6 ft and length of room is 530cm/208" or 17.4 ft.
and viewing distance from sofa is 14.3 ft
what are the realistic prospects of a descent projector room based on the measurements above.....i.e screen size etc..and good projector with food throw etc etc..
Old 01-11-2008, 12:59 PM   #11
4,708, Level: 16
Activity: 1.9%
Thanks for that, similar in dimension to what i would be looking at doing. As for projectors and screens you should have a look here
Projection Calculator - Throw Distance and Screen Size
select a projector and it will show you what screen sizes you can expect.
Old 01-11-2008, 4:24 PM   #12
Conspicuous Member
27,928, Level: 40
Activity: 18.2%
Those dimensions are almost identical to my old loft room. I'm not sure how high your side walls are or the angle of slope compared to mine, but if you do some measuring you might find that you can accommodate a similar sized screen to those I had.
I used to sit at 12ft, (1.5 x screen width) then later 10ft away from the screen (1.2 times sw). I've since found that I can quite happily sit at 1 times screen width away from a scope screen with no problems, and find it a more immersive experience, so try experimenting with seating distance to see what suits you. With a 720 resolution pj you may find that 1.2 is a limit due to the pixels becoming visible, but with 1080 it shouldn't be a problem.
Gary
Old 01-11-2008, 5:31 PM   #13
itn itn is offline
itn's Avatar
3,091, Level: 13
Ok, thanks for that!!.. what screen did you have mate. Also Is it better to buy the projector first then the screen?? Also can anyone reccommend a good wall mount for a projector. I would like it on the rear wall and not on a coffee table.
also what projector is reccomended for my distances?...
Old 01-11-2008, 5:41 PM   #14
Conspicuous Member
27,928, Level: 40
Activity: 18.2%
I made my own screens (see link in my sig) but Beamax and Carada get good reviews (as do others).
If you buy the pj first, you can experiment with screen sizes by projecting onto the wall where you want the screen to be and decide which is best for you.
The JVC HD1 has had good reviews and is available new for under £2000. It's being replaced by newer models but at the price the HD1 is a good deal. It might be an idea to read some reviews or better still, get a demo before buying. According to this calculator, you should be able to get a 7ft wide 16:9 screen (if your wall can fit it OK) with the JVC mounted on your rear wall:
There are others but that would probably be a good choice for a first pj. It's not perfect, but no pj is.
Gary
Old 01-11-2008, 6:03 PM   #15
itn itn is offline
itn's Avatar
3,091, Level: 13
£2k is way over my budget i was thinking more around the under £500 mark.... but im working out and planning by fit...and so need the best way to mount the projector. It has to be a wall mount and not a ceiling mount. Also how hight the the projector need to be mounted.
Old 02-11-2008, 9:02 AM   #16
inzaman's Avatar
22,352, Level: 36
Points: 22,352, Level: 36 Points: 22,352, Level: 36 Points: 22,352, Level: 36
Activity: 2.7%
Activity: 2.7% Activity: 2.7% Activity: 2.7%
Thanks: Gave 126, Got 543
If you are mounting the PJ on the rear wall then you could shelf mount which is what i have done. It only costs a few £ for the brackets, i then attached 9mm MDF and painted the same colour as the back wall so it blends in. As for the PJ ideally you would want one with lens shift as it will give you more flexibility. For £500 though you might need to look for a second hand one, i think
Old 02-11-2008, 10:26 AM   #17
3,273, Level: 13
Points: 3,273, Level: 13 Points: 3,273, Level: 13 Points: 3,273, Level: 13
Ive just installed one of these in my lounge and its fantastic Vogels EPW6565-SI - Projector Wall Solution, Click & Switch System, turn,tilt and roll, includes 1 x EPA6505 - EPW6565-SI
Old 04-11-2008, 5:45 PM   #18
itn itn is offline
itn's Avatar
3,091, Level: 13
how do you choose a projector to purchase for your room?.. do you base it on the approximate throwing distance you have?.. the wall or image size you want?.... IF the wall is triangular how do you choose the best image size?...
Length of room is 530cm/208" or 17.4 ft.
Old 05-11-2008, 11:34 PM   #19
itn itn is offline
itn's Avatar
3,091, Level: 13
bump!!
Old 06-11-2008, 10:57 AM   #20
inzaman's Avatar
22,352, Level: 36
Activity: 2.7%
I dont know about triangular wall, please explain further or show a picture.
With regards to the PJ the limiting factors are the throw distance, the PJ throw ratio and the PJs zoom. This does depend on the PJ you are thinking about getting. Some have small throw and large zoom lens (the new Panasonic AE3000) which will make it quite versatile. Also look for one with lens shift functionality as this also adds to the versatility.
Your viewing space or area looks very good from the sizes posted and you should find a range of PJs (probably most) that will be workable. With your viewing distance you could go for a 10 foot wide screen so look for PJs that can accomodate this. You might find your limiting factor to be the lumens output and the gain of screen required.
Old 06-11-2008, 2:46 PM   #21
itn itn is offline
itn's Avatar
3,091, Level: 13
i was refering to the wall on my pictures....i have a 5m throw...and i reckon i can just about squeeze in a 100" screen. Based on this how can i choose the projector?.. Using pj central site has just got me more confused!! aaahhhh help...im thinking I should now just go get a lasrge plasma!!...
Old 06-11-2008, 3:43 PM   #22
inzaman's Avatar
22,352, Level: 36
Activity: 2.7%
How much do you have to spend on a PJ and what models are you looking at/thinking about?
Old 06-11-2008, 6:40 PM   #23
itn itn is offline
itn's Avatar
3,091, Level: 13
budget is say between £500 and £700, cheaper i can get the more i can spend on speakers and a amp...etc etc..what else is connected in you homecinema?.. what amp did you go for?..
would it be worth going for a smaller screen one size less then the #100" so the wall doesnt look to filled up...or would you say the bigger the better?..
It wouldve been great if you were local i wouldve popped in for tea and Parathas at your!!
