Originally Posted by Jeff Hi IWC,
I'm thinking of making some stick on masking for my CIA screen, what black velvet material did you use?
My plan is some is have the masks cut to size, probably made out of thin perspex. Covered in black velvet with magnets glued to the back side. I should be able to simply clip them on to the frame and the magnets hold them in place. Very simple.
I like your screen by the way, very smart.  |
Hi Jeff,
Not that I disagree with IWC's solution, but if I'm not satisfied with the black bars on the 750, I plan to go in a direction very similar to the one you intend to go, and I wouldn't dismiss the "light" option so quickly.
I am going to do something similar to what the starter of this thread
I Made DIY 2.40:1 Masking for My 1.85:1 Screen - AVS Forum has done. Because my screen is too low due to height constraint in my room, I also plan to shift the picture up to the top of the screen when screening non 1.78 material, and have only one piece of masking per ratio (I think the opposite of you if I remember well, as you'd like to move your picture to the bottom of the screen).
If the material is light enough, you can definitely just "hang" your mask(s) beetween the sides of the screen, especially given the fact that your bars are smaller than on a 1.85 screen, which means you don't even need magnets or have to suffer a gap between the screen and the mask.
I'm tempted to try some of IWC's material, but it sounds like it's not as black as the "black hole" material used for the Carada screen. I've used for the rest of my batbin some black velvet which is quite inexpensive, and BLACKER than the black hole material form the Carada screen. Here is a link to it:
Standard Plain Velvet. It's only £6.5 per meter, and the fabric is anything between 1.20m to 1.50m wide (depending on the stock they use). They deliver within a couple of days.
Regarding the material, I've saved a few very large sheets of white polystyren that protected a wooden wardrobe we got delivered, and I plan to use that, wrapped with black velvet. So total cost for me is around £15...
Again, not disagreeing with IWC's solution which is very elegant, but heavy duty (and quite expensive comparatively).
