Yuki's New Media Room Project
| Post Reply |
| | #31 |
| Senior Member | Re: Yuki's New Media Room Project |
| Quote |
| Advert Log in or sign up to remove |
| | #33 |
| Quote |
| Thanks from: | chrisfoster1971 (27-12-2008) |
| | #34 |
| Quote |
| Thanks from: | yukichon (28-09-2008) |
| | #46 |
| Quote |
| Thanks from: | yukichon (30-09-2008) |
| Post Reply |
Im using some fancy expensive insulation which im told is very very good ...ill find out the name
... oh well we managed to pretty much finish the timber and bolting etc, of the roof , brikies should be back tomorrow to sort the gables out....then the roof on Wednesday if the weather is fine
Hence the reason for no longer needing a Garage
LinkBack URL
About LinkBacks
