Red wall, yay or nay?
Old 03-09-2008, 1:19 PM   #1
2,445, Level: 11
Points: 2,445, Level: 11 Points: 2,445, Level: 11 Points: 2,445, Level: 11
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 58, Got 17
Hi guys,
Looking at the room, it's a bit plain being all one cream colour so after seeing someone else's room in a nice red, i think mine could look pretty decent, what ya think? Another positive is that the dark red will hide my bad plastering better where i've laid wires behind the wall, hopefully.
Any ideas welcome.
Original
Photoshop
Old 03-09-2008, 1:39 PM   #2
4,017, Level: 14
Points: 4,017, Level: 14 Points: 4,017, Level: 14 Points: 4,017, Level: 14
Thanks: Gave 24, Got 22
Re: Red wall, yay or nay?
Yes definitely.... Burmese Ruby all the way.
Just to warn you - you'll probably need to put on about 4 coats
Copplepot (03-09-2008)
Old 03-09-2008, 1:44 PM   #3
2,445, Level: 11
Activity: 1.4%
Thank you, do you have any piccies with this Burmese Ruby? What size tin would you say for 4 coats for the wall?
Old 03-09-2008, 2:03 PM   #4
4,017, Level: 14
Sorry mate, these were all I could find - we used it on a dividing wall/chimney breast:
A couple of litres should do the job. Always water the paint down until it's a nice runny consistency - it means you'll need an extra coat (or 2) but it'll go on much easier than if you paint direct from the tin. I reckon you'll need 4 coats to get an even colour so don't worry when the first few coats look very patchy...
Old 03-09-2008, 2:27 PM   #5
2,967, Level: 12
Points: 2,967, Level: 12 Points: 2,967, Level: 12 Points: 2,967, Level: 12
Thanks: Gave 16, Got 16
Yes definatly. I also painted some of my walls red after seeing some one elses room on here. I used a colour called 'tinsel town' from wilkinsons Very nice colour indeed. You should get a tester
Old 03-09-2008, 2:30 PM   #6
2,445, Level: 11
Activity: 1.4%
Thanks guys, that red does look great! Will get some testers for both & see what i think although maybe a tad bit more dark.
Old 03-09-2008, 2:58 PM   #7
11,901, Level: 26
Points: 11,901, Level: 26 Points: 11,901, Level: 26 Points: 11,901, Level: 26
Thanks: Gave 2, Got 5
Hiya,
Just to add my 2p on this i have just finished my living room in a red / neutrel mix in a similar way to what you have mentioned. some pics are in my thread here Mark's Living Room Renovation
the Red I used was a Homebase Flawless Finish called Morrocan Red.
Old 03-09-2008, 3:24 PM   #8
2,445, Level: 11
Activity: 1.4%
Originally Posted by Pompey_Bungle View Post
Hiya,
I'm really liking that, will add that red to the sample list aswell. Living room rocks BTW.
Would red show up bumps worse then cream?
Old 04-09-2008, 12:15 PM   #9
3,718, Level: 14
Points: 3,718, Level: 14 Points: 3,718, Level: 14 Points: 3,718, Level: 14
Thanks: Gave 21, Got 55
We used roasted red on our bedroom feature wall. Your photoshoped wall looks much nicer than the plain one.
Old 04-09-2008, 12:18 PM   #10
Docta teef's Avatar
7,379, Level: 20
Points: 7,379, Level: 20 Points: 7,379, Level: 20 Points: 7,379, Level: 20
Thanks: Gave 42, Got 40
Do it, looks miles better
Old 04-09-2008, 1:46 PM   #11
4,088, Level: 15
Points: 4,088, Level: 15 Points: 4,088, Level: 15 Points: 4,088, Level: 15
Thanks: Gave 1, Got 21
I concur, might even have that colour behind my TV in my room
Old 04-09-2008, 2:17 PM   #12
1,493, Level: 8
Points: 1,493, Level: 8 Points: 1,493, Level: 8 Points: 1,493, Level: 8
Thanks: Gave 1, Got 26
defintely go for the red wall, a nice dark shade will look lovely in there
Old 05-09-2008, 3:23 PM   #13
3,201, Level: 13
Points: 3,201, Level: 13 Points: 3,201, Level: 13 Points: 3,201, Level: 13
Activity: 0.7%
Activity: 0.7% Activity: 0.7% Activity: 0.7%
Thanks: Gave 16, Got 6
I love my red wall
Old 05-09-2008, 5:09 PM   #14
4,121, Level: 15
Points: 4,121, Level: 15 Points: 4,121, Level: 15 Points: 4,121, Level: 15
Thanks: Gave 1, Got 6
nice wall
btw - that tania bird is quite fit in a dirty sorta way
Old 05-09-2008, 6:13 PM   #15
THE_FORCE's Avatar
21,983, Level: 36
Points: 21,983, Level: 36 Points: 21,983, Level: 36 Points: 21,983, Level: 36
Activity: 12.6%
Activity: 12.6% Activity: 12.6% Activity: 12.6%
Thanks: Gave 1,653, Got 1,037
Copplepot, just my two cents - unless your walls are really good, go with a matt finish, as a silk finish will show up imperfections. Also don't be afraid to go with a really bright, brilliant red, as opposed to a toned down pastel red. Maybe also think about painting the adjacent walls a brilliant white to really set it off, instead of keeping the magnolia. Good luck !
Old 05-09-2008, 10:38 PM   #16
11,901, Level: 26
Would totally agree with you there, I went for an off-white rather than brilliant, but used that for the skirting.. think main thing is to try and emphasise the red, good point on the matt finish as well as less chance for the light to sheen and show any imperfections
Old 06-09-2008, 7:18 AM   #17
THE_FORCE's Avatar
21,983, Level: 36
Activity: 12.6%
Cheers Pompey - just seen your room and it looks great mate !!
Just a quick example of the difference between the 2.
Red against the magnolia:
And red against the white:
What looks the 'cleaner' of the two ?
Copplepot (26-09-2008)
Old 06-09-2008, 9:35 AM   #18
8,188, Level: 21
Points: 8,188, Level: 21 Points: 8,188, Level: 21 Points: 8,188, Level: 21
Thanks: Gave 3, Got 64
Red will be fine!! - its the best shade I found to resemble almost the same qualities as black for cinema viewing:, Here I am using Red Stallion:
Old 07-09-2008, 5:38 PM   #19
jagdeepp's Avatar
9,709, Level: 23
Points: 9,709, Level: 23 Points: 9,709, Level: 23 Points: 9,709, Level: 23
Thanks: Gave 259, Got 161
Red wall for sure.. check out my thread in my signature to see how well the red offsets against the brilliant white skirting. FYI i used volcanic splash 2 by dulux.
Old 07-09-2008, 5:49 PM   #20
24,693, Level: 38
Points: 24,693, Level: 38 Points: 24,693, Level: 38 Points: 24,693, Level: 38
Thanks: Gave 639, Got 546
Definatley C
can`t you rub them down first, buy a little sander for £15 from B&Q and you`ll get a lovely smooth finish, don`t use your hand as you`ll end up with grooves from yer fingers and no skin
If money`s tight just buy a sanding block or use a piece of flat wood with some sand paper
Should look great when its done and also use a matt finish as Dave says
cheers Al
Old 07-09-2008, 9:20 PM   #21
5,201, Level: 17
Points: 5,201, Level: 17 Points: 5,201, Level: 17 Points: 5,201, Level: 17
Thanks: Gave 8, Got 24
I got some inspiration from this thread and made it my weekend project!!
Before:
After:
I'm well pleased and I think its made a big difference to the lounge.
Steve
Old 08-09-2008, 12:08 AM   #22
3,201, Level: 13
Activity: 0.7%
Originally Posted by davelee212 View Post
nice wall
hee hee
Old 15-10-2008, 11:18 AM   #23
2,445, Level: 11
Activity: 1.4%
Bit of an update, i went for 'Cherry red' in the end & this is how it looks.
Old 15-10-2008, 12:53 PM   #24
4,552, Level: 16
Points: 4,552, Level: 16 Points: 4,552, Level: 16 Points: 4,552, Level: 16
Activity: 0.8%
Activity: 0.8% Activity: 0.8% Activity: 0.8%
Thanks: Gave 24, Got 167
Thats quite nice actually...didn't think it was going to be! Still got to do something with that plug socket and cable though.
Old 16-10-2008, 9:30 AM   #25
1,476, Level: 8
Points: 1,476, Level: 8 Points: 1,476, Level: 8 Points: 1,476, Level: 8
Activity: 0.9%
Activity: 0.9% Activity: 0.9% Activity: 0.9%
Originally Posted by blincoe73 View Post
I love my red wall
Where did you get those cabinets from?
Old 24-10-2008, 9:51 PM   #26
3,201, Level: 13
Activity: 0.7%
Ikea
