Running speaker cable outside a building
Old 03-09-2008, 8:44 AM   #1
21,436, Level: 35
Points: 21,436, Level: 35 Points: 21,436, Level: 35 Points: 21,436, Level: 35
Activity: 5.8%
Activity: 5.8% Activity: 5.8% Activity: 5.8%
Thanks: Gave 239, Got 101
Hello.
Only had my extension built about a year ago, at that time had speaker cable chased into the wall.
I need to change the rear speaker positions and upgrade the quality of cable.
Rather than chasing into the walls and then filling/painting etc I could just drill out, run the cable round the outside of this single storey detached extension and then drill back in again at the appropriate places.
Does this sound like a better idea than chasing?
Old 03-09-2008, 12:25 PM   #2
stretcher's Avatar
4,740, Level: 16
Points: 4,740, Level: 16 Points: 4,740, Level: 16 Points: 4,740, Level: 16
Thanks: Gave 29, Got 7
Re: Running speaker cable outside a building
Why not run some plastic conduit to protect the wire if you're putting some decent quality stuff in - that's what I did, - pretty cheap from B&Q as well
