Cable ties to attach to joists
Old 01-09-2008, 5:57 PM   #1
2,386, Level: 11
Points: 2,386, Level: 11 Points: 2,386, Level: 11 Points: 2,386, Level: 11
Thanks: Gave 9, Got 2
Hi, I've seen a cable tie type product that can be screwed/nailed to joist then hold the cables in place, now I need them I can't find the website!
Does anyone know where I can get these?
thanks,
Old 01-09-2008, 6:57 PM   #2
4,111, Level: 15
Points: 4,111, Level: 15 Points: 4,111, Level: 15 Points: 4,111, Level: 15
Thanks: Gave 23, Got 32
Re: Cable ties to attach to joists
I believe this is what you are after:
http://www.screwfix.com/prods/73716/...mm-Pack-of-100
Although it has a self-adhesive back it looks like you can screw them to the surface and feed a standard cable tie through.
cford2010 (02-09-2008)
Old 01-09-2008, 7:45 PM   #3
8,116, Level: 21
Points: 8,116, Level: 21 Points: 8,116, Level: 21 Points: 8,116, Level: 21
Thanks: Gave 25, Got 91
Those things are great. Stick in in place first and then whack a screw through and they wont shift! Just dont go too deep with the screw coz itll go straight through the plastic!
Old 01-09-2008, 8:22 PM   #4
2,542, Level: 11
Points: 2,542, Level: 11 Points: 2,542, Level: 11 Points: 2,542, Level: 11
Thanks: Gave 7, Got 79
Here are some intended for fixing with a screw:
http://shop.comdir.co.uk/Products.as...rWebTemplate=C
Old 02-09-2008, 2:40 PM   #5
2,386, Level: 11
Thanks for the replies, just what I was looking for!
