Help with HTPC
Thread Closed
Old 01-09-2008, 1:19 AM   #1
beastofrock's Avatar
3,275, Level: 13
Points: 3,275, Level: 13 Points: 3,275, Level: 13 Points: 3,275, Level: 13
Activity: 6.1%
Activity: 6.1% Activity: 6.1% Activity: 6.1%
Thanks: Gave 98, Got 55
Help with HTPC
ok well at home were just waiting on planning permission to convert our barn into a living space for myself and my friend and it was also be a home cinema for us, the barn isnt the biggest of spaces so any room we can save the better.
i have been looking at HTPCs but really dont understand they work, money isnt really an object so we would be looking for the best money can offer or something cheap but will do the job just aswell, mainly to put blu rays onto and then play onto our tv/projecter
Old 01-09-2008, 8:44 AM   #2
FunkyMunkey's Avatar
5,052, Level: 16
Points: 5,052, Level: 16 Points: 5,052, Level: 16 Points: 5,052, Level: 16
Thanks: Gave 234, Got 115
Re: Help with HTPC
This would probably be better off in the Home Cinema PC forum.
There's not really much to understand. Have you built a PC before?
It's a basically the same as building a normal PC, but with slightly different components (such as a Blu-Ray drive and a motherboard with an HDMI output).
Have a look at this thread on the Home Cinema PC forum for more info
beastofrock (01-09-2008)
Old 01-09-2008, 9:11 AM   #3
3,275, Level: 13
Activity: 6.1%
Re: Help with HTPC
thanks for the info FunkyMunky, could a mod please close this thread while i read through all the info and if i need any help then i will have a look post on that forum
Thread Closed
