Hiding Wires with wall mount?
Old 28-08-2008, 9:11 AM   #1
3,856, Level: 14
Points: 3,856, Level: 14 Points: 3,856, Level: 14 Points: 3,856, Level: 14
Thanks: Gave 1, Got 0
Im going to wallmount my LCD monitor but I dont know how to hide the wires coming down the wall? Ive seen many people do it but im stuck as to how they do that! Any ideas or tips, its a white wall if that helps.
Old 28-08-2008, 10:58 AM   #2
2,981, Level: 12
Points: 2,981, Level: 12 Points: 2,981, Level: 12 Points: 2,981, Level: 12
Thanks: Gave 5, Got 5
Re: Hiding Wires with wall mount?
you have two options really
1. chase a channel in the wall, put the cables in and plaster over them & re paint
2. Buy some conduit from B&Q - they do all sorts of shapes, sizes and colours now rather than the old bog standard square stuff
hope that helps
Old 28-08-2008, 12:09 PM   #3
dj-dulux's Avatar
4,384, Level: 15
Points: 4,384, Level: 15 Points: 4,384, Level: 15 Points: 4,384, Level: 15
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 10, Got 132
As appledrone has said either chase:
To get clean finish:
Or trunking:
Dupe...
Old 30-08-2008, 12:27 AM   #4
2,865, Level: 12
Points: 2,865, Level: 12 Points: 2,865, Level: 12 Points: 2,865, Level: 12
Isn't there a way to use some form of "hidden trunking" eg. actually flush with the wall? This would also allow for future add-ons, future upgrades in av equipment?
