Originally Posted by shahedz thanks for the replies fellas. the one from stand deliver is huge, it's going in my bedroom which is in the loft so space is limited. The benno is what i really wanted but the drawers instead of doors put me off.
I am not moved towards the 2 pieces that go together the width of 170 is what i need to see if i can accomodate. thanks  |
With the Benno you could consider diying the drawers into doors and putting in an additional shelf. If you have an ikea nearby then go take a look. My parents have one and I was going to mess about with the layout, keep the drawer mechanism for the front but use it like a sliding door and have the extra shelf but in the end my parents lack of equipment meant it really wasn't necessary.
I wish I had checked the back before cobbling it all together. The back comes in two pieces, joined vertically, but you are meant to connect each side seperatley. The problem is that the predrilled holes the back screws into actually leaves the two pieces misalligned. Far better to connect the back and then reposition the holes for a smarter finish.
