| Re: Muxlab AV plus balans for Cat5 distribution an option?
Muxlab Baluns are point to point solutions. If you have several Sky receivers in one centralized location and each receiver is going to one TV, then you can use Muxlab Component or HDMI baluns to send Video, Audio and Controls over CAT5e.
I suggest taking a look at Muxlab's active component balun 500090. It can send component, Stereo Audio, Digital Audio and IR over (1) CAT5e cable. The other option is using a pair of Component Video/IR Pass-Thru Balun 500054 for Video and IR then use a seperate Stereo Audio balun 500027 for audio. The HDMI baluns 500400 can also send Video and Audio over CAT5e.
I suggest taking a look at them on the muxlab website. These solutions will be much cheaper then the alternatives mentioned here.
