Where to get in-floor lights?
Old 18-08-2008, 12:01 PM   #1
3,225, Level: 13
Points: 3,225, Level: 13 Points: 3,225, Level: 13 Points: 3,225, Level: 13
Thanks: Gave 15, Got 28
Does anyone know where to buy the lights that Cinema's have to guide to the exits etc, also used for the same reason on aircraft.
I've done some searching and not found anything suitable so far.
help...
Old 18-08-2008, 1:23 PM   #2
7,058, Level: 20
Points: 7,058, Level: 20 Points: 7,058, Level: 20 Points: 7,058, Level: 20
Thanks: Gave 0, Got 4
Re: Where to get in-floor lights?
B&Q do some led ones which are designed to go into outside decking, so they may work for you.
Link
Old 17-09-2008, 7:00 PM   #3
thefathacker's Avatar
1,922, Level: 10
Points: 1,922, Level: 10 Points: 1,922, Level: 10 Points: 1,922, Level: 10
Thanks: Gave 16, Got 3
Not sure of the exact spec. of what you are after, but I have had floor uplighting LED's from here in the past.
http://www.micromark.co.uk
