Originally Posted by saintstephen I have the tv above a coal buring fireplace  for a year now ...no problem Attachment 88474 |
Is it me, or does that attachment not work?
Anyway, a Pioneer dealer told me that he's mounted plasmas above working fireplaces, and - as long as they're working efficiently (i.e. not chucking out huge amounts of soot, and are throwing heat into the room rather than up the chimney, etc.) it should be fine. The usual advice seems to be to get a roaring fire going/stick your gas fire on maximum (daft idea in summer, I know) and check the temperature of the brickwork (or whatever) in the area where the TV will hang. If it's not really hot, you should be OK. Apparently a really thick/wide mantlepiece is helpful as well.
I should point out, I haven't followed this advice myself yet - still making doing with a Toshiba CRT in front of the bay window, but am saving my pennies for a Pio plasma which is going to have to hang on the chimney breast over an (occasionally) working (open) fire. In my living room there's nowhere else for it to go!
Let me know how you get on, leedspokerguru!
Best wishes
Martin
