DIY Sub Mk.3 RTP-12 *Completed*
Old 19-05-2003, 12:53 PM   #1
ReTrO's Avatar
15,958, Level: 30
Points: 15,958, Level: 30 Points: 15,958, Level: 30 Points: 15,958, Level: 30
Thanks: Gave 14, Got 51
DIY Sub Mk.3 RTP-12 *Completed (Title thread updated)*
Coming soon is the RTP-12.
Based around a 12" driver, it will be very similar to the famous REL Q100e.
The sub is being made for a fellow forum member.
More coming soon.
Old 19-05-2003, 4:27 PM   #2
shodan's Avatar
8,221, Level: 21
Points: 8,221, Level: 21 Points: 8,221, Level: 21 Points: 8,221, Level: 21
Activity: 6.8%
Activity: 6.8% Activity: 6.8% Activity: 6.8%
Thanks: Gave 206, Got 579
I shall be following this one with great interest!!! :-)
Old 19-05-2003, 4:33 PM   #3
ReTrO's Avatar
15,958, Level: 30
Have you got any suggestions for the styling of the enclosure Shodan?
Old 19-05-2003, 10:16 PM   #4
Taz
Posts: n/a
Sounds good!
Old 19-05-2003, 11:26 PM   #5
ReTrO's Avatar
15,958, Level: 30
Design work is progressing well with the RTP-12.
Things that need finalising, assuming the driver and amp combination to be used (more on that later), are the grill and finish.
Not too much then. :D
Old 20-05-2003, 2:16 PM   #6
shodan's Avatar
8,221, Level: 21
Activity: 6.8%
Err, kinda box shaped? Made of wood? I dunno. Do you mean what kind of colouring for the finish?
How about a removable grill? Just so I can see it working until the novelty wears off and I leave it covered after that. But that aspect isn't too important to me.
I'm a complete newbie to subs so I am entirely at the mercy of Retro & Taz Productions!!!
Old 20-05-2003, 2:23 PM   #7
ReTrO's Avatar
15,958, Level: 30
Ideas are always welcome.
I'll email you some ideas this week.
Old 20-05-2003, 2:26 PM   #8
shodan's Avatar
8,221, Level: 21
Activity: 6.8%
Cool! I'm actually PM you my e-amil address so you can use that or the forums PM thingy.
Cheers again matey!
Old 28-05-2003, 2:46 AM   #9
ReTrO's Avatar
15,958, Level: 30
Work has been done on the new front baffle for the sub, and a new back panel.
These are due to be fitted this week, restrictions permitting.
Pictures should follow very soon.
The electronic parts for this sub are as follows:
Driver: BSB 12" 100W
Amplifier panel: BSB 100
At the moment the only thing I am pondering design wise is whether to add feet to the sub or not. And then what sort of feet to add.
Ho hum....
Old 28-05-2003, 2:57 AM   #10
ReTrO's Avatar
15,958, Level: 30
Pictures as promised:
1) The old RTP-10 enclosure front baffle, minus its electronics and fablon.
Old 28-05-2003, 3:01 AM   #11
ReTrO's Avatar
15,958, Level: 30
2) Designs for modified RTP-10 enclosure to RTP-12 specification.
Showing bracing.
Old 28-05-2003, 3:01 AM   #12
ReTrO's Avatar
15,958, Level: 30
3) Further design pictures.
Showing the rear panel.
Old 28-05-2003, 3:02 AM   #13
ReTrO's Avatar
15,958, Level: 30
4) Another design picture. Shown from the front.
Old 28-05-2003, 3:04 AM   #14
ReTrO's Avatar
15,958, Level: 30
5) Back panel, with amplifier cutout.
Old 28-05-2003, 3:04 AM   #15
ReTrO's Avatar
15,958, Level: 30
6) New front baffle.
Old 28-05-2003, 3:05 AM   #16
ReTrO's Avatar
15,958, Level: 30
7) New back and front baffles.
Old 28-05-2003, 3:06 AM   #17
ReTrO's Avatar
15,958, Level: 30
8) Alternative view.
Old 28-05-2003, 3:07 AM   #18
ReTrO's Avatar
15,958, Level: 30
9) New front baffle on old front baffle. Showing driver hole size differences.
Old 28-05-2003, 1:05 PM   #19
shodan's Avatar
8,221, Level: 21
Activity: 6.8%
Looking good ReTrO!!! So's the sub...;-)
Its all getting very exciting now!!!
What difference does having feet on it make? Apart from protecting the bottom from hard surfaces? Also, what types of feet could be considered and would you advise 3 in a triangle formation or four (onr under each corner).
Thanks again guys, stirling job!!!
Old 28-05-2003, 1:11 PM   #20
ReTrO's Avatar
15,958, Level: 30
The feet thing was throwing me, as you may have guessed.
3 would be more stable, though also potentially a bit wobbly and unbalanced. I'd be inclined to go with 4.
As for what sort. Well i'd be more tempted to get a set of large rubber stick on feet to start with, and then maybe look at buying a set of screw in spikes.
I think I'll add some to the RTP-15 at a later date. This will help prevent damage to the grill cloth.
I'll try to find some spikes links.
Old 28-05-2003, 1:20 PM   #21
shodan's Avatar
8,221, Level: 21
Activity: 6.8%
I was thinking that they cant be that difficult to fit (can they?) so if you like, I'm quite happy to have no feet on it - makes it easier for you!!! - and I'll put some on later if I think she needs them..
Old 28-05-2003, 1:22 PM   #22
ReTrO's Avatar
15,958, Level: 30
Yeah. The feet are the easiest bit to add on.
Just thinking for ideas more than anything else at the mo.
Old 29-05-2003, 3:00 AM   #23
ReTrO's Avatar
15,958, Level: 30
New photos of the sub
New photos of the sub.
These show the enclosure in the nude, constructed by Taz.
10) New back baffle.
Old 29-05-2003, 3:01 AM   #24
ReTrO's Avatar
15,958, Level: 30
11) New front baffle.
Old 29-05-2003, 3:02 AM   #25
ReTrO's Avatar
15,958, Level: 30
12) Whole thing.
Old 29-05-2003, 3:09 AM   #26
shodan's Avatar
8,221, Level: 21
Activity: 6.8%
Looking absolutely brilliant guys! Looks like a thoroughly proffesional job!
Man, that is one sexy box....
Old 01-06-2003, 5:55 PM   #27
Taz
Posts: n/a
Update....
Starting to cover with beech Fablon.....
Old 01-06-2003, 5:56 PM   #28
Taz
Posts: n/a
Iso view...........
Old 01-06-2003, 5:57 PM   #29
Taz
Posts: n/a
Since the front is veneered, i applied the Fablon to give the look that its a solid block of timber and it works well!.....
Old 01-06-2003, 5:58 PM   #30
Taz
Posts: n/a
Another view .........
(Thanks to Mrs Taz for helping with fablon! )
