any ideas for radiator suppliers?
Old 08-05-2003, 2:52 AM   #1
alistair
Posts: n/a
i need to replace a 600mm high standard radiator with a 300mm high one to accommodate an in-wall speaker. i haven't had much joy finding anything suitable (and reasonable £s). anyone got any ideas where to go? supply & fit would be good. thx
Old 09-05-2003, 5:28 PM   #2
menalaus's Avatar
3,505, Level: 13
Points: 3,505, Level: 13 Points: 3,505, Level: 13 Points: 3,505, Level: 13
Thanks: Gave 2, Got 5
try here www.screwfix.com
Old 09-05-2003, 10:38 PM   #3
alistair
Posts: n/a
thanks for that, I was beginning to think no one cared!
all I need is a plumber now
rgds
Old 10-05-2003, 4:20 AM   #4
Thanks: Gave 0, Got 9
Try:
The Radiator Company - The web site isn't very useful IMHO but ask for a brochure. A really great selection of classic, modern and darn right funky rads.
www.theradiatorcompany.co.uk
ro...
Myson - Good selection of more traditional types of rads.
I believe they are quite well know in the building industry if piece of mind is a factor.
www.myson.co.uk
Good luck.
RAMiAM IamRAM
