DIY Sub Mk.2 RTP-15
Old 08-05-2003, 1:17 AM   #1
ReTrO's Avatar
15,958, Level: 30
Points: 15,958, Level: 30 Points: 15,958, Level: 30 Points: 15,958, Level: 30
Thanks: Gave 14, Got 51
DIY Sub Mk.2 RTP-15
Lost this first time around so here we go again.
ReTrO & Taz Productions welcome you to another DIY audio masterpiece.
RTP-15
This subwoofer utilises an Adire Audio Temepst 15" bass driver fitted inside the Adire reference small enclosure (65L). The enclosure has been made by Taz, using the latest MDF bonding techniques (involving lots of high voltages, yeah!)
It will be using an unknown amplifer at present, but it will most likely be either a BKElec DT300 plate amp or a pair of BKElec 200w amp modules. In the short term it will use the 110 amp module from the Mk.1 RTP-10 project.
It has a 12 band parametric eq offboard, in the form of a Behringer Feedback Destroyer Pro DSP 1124P , to help with the in-room response.
The enclosure will be finished in black ash fablon, as supplied and fitted by the man Taz himself. I will be making a stretchy sock grill to go over the front.
Here are some pictures so far.
Old 08-05-2003, 1:17 AM   #2
ReTrO's Avatar
15,958, Level: 30
2nd pic
Old 08-05-2003, 1:18 AM   #3
ReTrO's Avatar
15,958, Level: 30
3rd pic
Old 08-05-2003, 1:18 AM   #4
ReTrO's Avatar
15,958, Level: 30
4th pic
Old 08-05-2003, 1:18 AM   #5
ReTrO's Avatar
15,958, Level: 30
5th pic
Old 08-05-2003, 1:42 AM   #6
Taz
Posts: n/a
Originally posted by ReTrO
4th pic
And may I say, its the best so far
Look, you can see my amp in the background
Old 08-05-2003, 1:46 AM   #7
ReTrO's Avatar
15,958, Level: 30
So you can, hadn't noticed that before.
Old 08-05-2003, 2:37 AM   #8
6,344, Level: 18
Points: 6,344, Level: 18 Points: 6,344, Level: 18 Points: 6,344, Level: 18
Thanks: Gave 6, Got 73
Looks good as always but why the High Q 0.9 design you will be getting a lot more output in the higher bass region, the EQ will help a lot but a mid Q 0.707 or even a lower Q design would probebly sound deeper for home cinema.
Old 08-05-2003, 3:01 AM   #9
ReTrO's Avatar
15,958, Level: 30
Space is an issue here micb3rd. Otherwise I would have gone for much larger box or maybe even an IB design in a wall or door.
I reckon we may be able to get away with a touch of EQ to rbing the bottom end out a bit, though it may not be needed if it can shift the air well.
Old 09-05-2003, 12:06 AM   #10
colinstone's Avatar
6,368, Level: 19
Points: 6,368, Level: 19 Points: 6,368, Level: 19 Points: 6,368, Level: 19
What about building a sub into the floor?? - with all the box etc below the floorboards and speaker grille recessed into the floor??
I can access below the floor very simply.
Old 09-05-2003, 12:07 AM   #11
nathan_silly
Posts: n/a
This is my setup
http://www.royaldevice.com/custom3.htm
Old 09-05-2003, 12:25 AM   #12
ReTrO's Avatar
15,958, Level: 30
That is something I would consider if I owned my own house and had a job.
My HC at home is in a spare bedroom when there's some space. I'm hoping to get a room built ar some point though in me garden if I'm still at home when I have a good job.
Old 09-05-2003, 11:31 AM   #13
ReTrO's Avatar
15,958, Level: 30
It will be to partner it sort of replace it. I've not had the pleasure of using the JL myself because I've been at Uni and the sub's been at Taz's place.
He will be using the Temepest one also for a while. Hope he enjoys it.
Old 09-05-2003, 5:34 PM   #14
colinstone's Avatar
6,368, Level: 19
Nathan_silly - I was notthinking of anything that extreme!!! May be just a decent sized MDF box with a good sized driver.
Old 09-05-2003, 10:20 PM   #15
6,692, Level: 19
Points: 6,692, Level: 19 Points: 6,692, Level: 19 Points: 6,692, Level: 19
Thanks: Gave 20, Got 13
That's what I've done!
Old 10-05-2003, 10:04 AM   #16
Taz
Posts: n/a
Old 10-05-2003, 6:34 PM   #17
ReTrO's Avatar
15,958, Level: 30
The BFD has now arrived with Mr Taz, which is good news.
I've given up on Maplin sending me the correct cable, so I'm going to make up the leads for now with the Van Damme Unbalanced Patch cable they have sent, should be pretty good anyway.
The cable will be on it's way hopefully on wednesday, so that the BFD can be given a run.
All is looking good.
ED: Just ordered the speaker cloth from Maplin along with some more acoustic wadding.
Old 11-05-2003, 4:35 AM   #18
ReTrO's Avatar
15,958, Level: 30
I also ordered today some 'more' of the Van Damme Starquad mic cable, hopefully it will arrive correctly this time. I have also ordered a pair of Neutrik Profi phono plugs from Maplin.
I have found the build quality of all the Neutrik products to be very high, and can recommend them to anybody.
www.neutrik.com
Old 14-05-2003, 3:19 AM   #19
ReTrO's Avatar
15,958, Level: 30
Update:
The correct Van Damme cable and the Neutrik Profi phono's arrived on monday morning and were made up into the correct leads. These being 1m phono to 1/4" jack and 3m 1/4" jack to phono, for processor to BFD to sub accordingly.
These will be despatched in the morning, and hopefully be with Taz to play with over the weekend.
In the meantime I have been have bad ideas about making another sub based around the BKElec BSB 12 100 and a 100w plate amp. Either a BSB 100 @ £118, or a DT 150 @ £103. This would be put into a 50L enclosure (approx 400x400x420mm external), and would basically be a REL Q100E. Costs for this would be between £150-200 to make, and should end with a very satisfying subwoofer.
Old 14-05-2003, 1:00 PM   #20
10,119, Level: 24
Points: 10,119, Level: 24 Points: 10,119, Level: 24 Points: 10,119, Level: 24
Would you use any EQ with that? Linkwitz? I'm still umming about what to do for my sub project, but reckon the Shiva/Lab12 is still the way to go.
Old 14-05-2003, 1:11 PM   #21
ReTrO's Avatar
15,958, Level: 30
I guess you mean with a BSB driver.
If I went down that avenue I would build a pair of the subs and use one channel of the BFD for each. These would be attached to the left and right front channels, or as left and right subs, depending on what processing I will be using.
I've just updated my Room Arranger ideal room to show this.
Old 14-05-2003, 10:59 PM   #22
ReTrO's Avatar
15,958, Level: 30
Didn't send off the cables today because I fell asleep at me PC at about 2ish.
Will get them off tomorrow.
Old 14-05-2003, 11:10 PM   #23
Taz
Posts: n/a
Old 19-05-2003, 12:51 PM   #24
ReTrO's Avatar
15,958, Level: 30
Cables arrived with Taz on saturday.
Connection will be done saturday 24th after the second sub has been completed, and tattoos have been applied to various constructors.
Old 20-05-2003, 5:28 AM   #25
TorAtle
Posts: n/a
Why not use a Linkwitz transform EQ? You could have a lower Q and a lower -3db for the price of less SPL.
Old 20-05-2003, 12:15 PM   #26
ReTrO's Avatar
15,958, Level: 30
We shall have to see how it performs EQ'less to start with. Then we'll be giving the BFD a run to see what difference it can make.
Old 24-05-2003, 9:52 PM   #27
Taz
Posts: n/a
Some pics of the project going together this afternoon!
Review to follow
Old 24-05-2003, 9:53 PM   #28
Taz
Posts: n/a
Rick and bits!
Old 24-05-2003, 9:54 PM   #29
Taz
Posts: n/a
Where does this bit go!
Old 24-05-2003, 9:54 PM   #30
Taz
Posts: n/a
Rick gets it sorted!
