acoustic underlay for laminate
Old 09-06-2008, 9:58 AM   #1
akewt's Avatar
4,830, Level: 16
Points: 4,830, Level: 16 Points: 4,830, Level: 16 Points: 4,830, Level: 16
Thanks: Gave 25, Got 5
can anyone suggest some underlay for laminate flooring which has good acoustic properties and a good thickness so i can channel speaker cables around the edge of the room?
im not interested in acoustic perfection just something that is better than standard stuff and not too dear.
thanks for any comments
Old 09-06-2008, 11:37 AM   #2
2,635, Level: 11
Points: 2,635, Level: 11 Points: 2,635, Level: 11 Points: 2,635, Level: 11
Re: acoustic underlay for laminate
I used a layer of this:
http://www.flooring-exposed.com/fine...-96m2-31-p.asp
Then a layer of this:
http://www.flooring-exposed.com/cush...rlay-101-p.asp
And acoustically it's great. There are cheaper places for them if you look around on the net but these are what i came across first.
I needed a good sound insulation solution as i live in a first floor flat and didn't want to have any problems with noise transfer to down stairs.
akewt (09-06-2008)
Old 09-06-2008, 1:29 PM   #3
akewt's Avatar
4,830, Level: 16
found some of the Fine Floor Fibre Board here for around £10:
http://www.carpet-underlay-shop.co.u...003m2-31-p.asp
thinking i may only need this stuff and some standard underlay
http://www.carpet-underlay-shop.co.u...10m2-179-p.asp
Old 10-06-2008, 11:47 AM   #4
3,718, Level: 14
Points: 3,718, Level: 14 Points: 3,718, Level: 14 Points: 3,718, Level: 14
Thanks: Gave 21, Got 55
I used the fibre stuff under my laminate and its still very noise down stairs when people are walking above you. I would be tempted to try the stuff chri$ linked too.
Old 10-06-2008, 1:05 PM   #5
akewt's Avatar
4,830, Level: 16
problem with that good underlay is the room is just over 15m2 so would have to buy 2 rolls for just an extra couple of metres!!
Old 10-06-2008, 8:44 PM   #6
dodfaefife's Avatar
3,415, Level: 13
Points: 3,415, Level: 13 Points: 3,415, Level: 13 Points: 3,415, Level: 13
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 7, Got 12
Hi all.
About to lay a new laminate floor myself. Does anyone know if the 'Cush'n'Wood' is suitable for use with underfloor heating (electric element type)? Wondering if it would allow the heat to pass through. The current floor is 12mm engineered stuff over a rubber barrier and heats up fine but is noisy. I'm guessing that replacing that with an 8mm and underlay won't restrict the heat – unless the underlay had a thermal barrier layer. Any advice welcome.
Old 11-06-2008, 12:11 PM   #7
2,635, Level: 11
Have a look at the products here. Says which are suitable for under floor heating.
http://www.carpet-underlay-shop.co.u...AYCAT&catid=14
Old 11-06-2008, 4:03 PM   #8
dodfaefife's Avatar
3,415, Level: 13
Activity: 1.4%
Cheers chri$
Will check them out.
