fixing batons
Old 06-06-2008, 10:08 PM   #1
2,556, Level: 11
Points: 2,556, Level: 11 Points: 2,556, Level: 11 Points: 2,556, Level: 11
Thanks: Gave 16, Got 3
fixing batons
how many fixings should i use in each baton i have two batons that are 225cm for the left and right sides and two that are 175cm for the top and bottom .
Old 07-06-2008, 10:41 AM   #2
paulyoung666's Avatar
5,686, Level: 17
Points: 5,686, Level: 17 Points: 5,686, Level: 17 Points: 5,686, Level: 17
Activity: 1.4%
Activity: 1.4% Activity: 1.4% Activity: 1.4%
Thanks: Gave 266, Got 379
Re: fixing batons
as many as you can , seriously , are you on about fixing timber to tiimber ??? , if you are then i would get some steel corner brackets from b&q or wherever , helps to firm the corners up
Old 07-06-2008, 2:15 PM   #3
2,556, Level: 11
Re: fixing batons
fixing the wood to the wall to make like a floating wall then mdf to the batons
Old 07-06-2008, 5:33 PM   #4
5,686, Level: 17
Activity: 1.4%
Re: fixing batons
1 good fixing every 300 mm should be more than enough i reckon , dont use plugs and screws , you want anchors , i.e. rawlbolts , pick the right type for the wall you are fixing to ( brick / concrete block or thermalite block ) and you are good to go
