Sound insulation in false wall (choices and fitting)
Old 05-06-2008, 4:31 PM   #1
3,541, Level: 13
Points: 3,541, Level: 13 Points: 3,541, Level: 13 Points: 3,541, Level: 13
Thanks: Gave 12, Got 8
Hello All,
Building a false wall and want to fill the void that isn't filled with cables with sound insulation, and the most common thing for that seems to be rockwool. So:-
Does anyone know a decent supplier (looked on the interweb and there isn't anything obvious for someone with no idea).
Is there any benefit from using slab or roll?
How do I fix it to a vertical wall so it doesn't slump? (should I see question above...?)
Does anyone know anything about how effective sheeps wool might be?
Thanks for reading
Old 09-06-2008, 1:29 PM   #2
3,541, Level: 13
Re: Sound insulation in false wall (choices and fitting)
Anyone?
Old 09-06-2008, 2:48 PM   #3
apul's Avatar
4,428, Level: 15
Points: 4,428, Level: 15 Points: 4,428, Level: 15 Points: 4,428, Level: 15
Thanks: Gave 99, Got 16
I'm suprised no one has replied to you yet.
This website has some good guides how to soundproof walls.
http://www.customaudiodesigns.co.uk/help.htm
Not bought anything from here before.
As for slumping, you can either use a spray adhesive or we've just packed it in tight enought so it wont slump. We also bought acoustic mineral wool from our local building suppliers.
tojo (12-06-2008)
